03-24-2010, 09:34 | #5 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Faisalabad pakistan
Member: 900083 Status: Offline Thanks Meter: 601 | i try with safe and complete formatffs here is logs COM4 selected module v3.03 Device: Alcatel-S621X, S621A Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:7C03:A006 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22422200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: D:\infinity installed\MModule\backup_security\id.6493D4A9.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_DF65B65F].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 6493D4A9 rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN project-id: MAUI.06B.W07.28.SP1.V34, 5FB665DF code offset: 00000000 ffs offset/size [01]: 01020000/00FE0000 TCL-ID identification version: 544 provider: S621X-2AALAP1 customization: CD54BM02 customization: XD54BM02 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01020000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35199002008262 flash: 01227E22422200:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22422200:18E59F00000000 error: error# 0000002B error: flash erase error: 019C0000 error: error# 0000006F error: flash erase error: 019C0000 error: error# 0000006F error: flash erase error: 019C0000 error: error# 0000006F error: flash erase error: 019C0000 error: error# 0000002B error: flash erase error: 019C0000 error: error# 0000006F error: flash erase error: 019C0000 error: format ffs failed Finalization Fail file saved: D:\infinity installed\MModule\backup_security\Alcatel-S621X,S621A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_6493D4A9_DF65B65F_20 100324-131657.B0X.bin Finished, time used: 1 min 52 sec Remove/Install battery now ! |
Alcatel S621 After Flash Stuck on Logo | ..::Angel::.. | Infinity-Box | 11 | 05-31-2010 12:57 |
alcatel s621 how to remove full lock on it | hik | Alcatel TCL Phones and New Models | 2 | 03-13-2010 21:32 |
S621 Hang At Start Up Logo. | alamgarh | Infinity-Box | 8 | 06-10-2009 07:32 |
alcatel s621 unlock flash need | G$M solution | Infinity-Box | 5 | 02-05-2009 16:05 |
alcatel v770x hang on alcatel done 100% | aliakbar | Infinity-Box | 1 | 02-03-2009 18:44 |
