05-12-2015, 08:55 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Android 5.x PatternLock? Easy :D Code: Operation : Check / Read Info [ v1.20 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6752 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6732|MT6752_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100523832314D42004CD7D00B222B DA Stat : v4.2 on BBID : 0x8F DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BM128 [eMMC] : FLASH_CID : 150100523832314D42004CD7D00B222B [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : k01q_h ProdModel : k01q_h Device : k01q_h AndroidVer: 5.0 MTKxCPU : MT6752 MTKxPRJ : ALPS.L0.MP6.V3.20_NB6752.LWT.CU_P2 Done! Elapsed: 00:00:25 Reconnect Power/Cable! Code: Operation : Read PatternLock [ v1.20 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6752 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6732|MT6752_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100523832314D42004CD7D00B222B DA Stat : v4.2 on BBID : 0x8F DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BM128 [eMMC] : FLASH_CID : 150100523832314D42004CD7D00B222B [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 12237 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock Sequnce : 124569 Done! Elapsed: 00:00:51 Reconnect Power/Cable! |
The Following 11 Users Say Thank You to JayDi For This Useful Post: |
05-13-2015, 08:41 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | P.S. : If some one get Android 5.x MTK with "Data Protection" enabled ( this is MTK - specified feature ) - let me know in PM, can give some version with support of read and removing that function. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
