Old 11-08-2009, 17:39   #1 (permalink)
Member: 253726
Sonork: 100 1605478
Thanks Meter: 21
help,can't boot mode any phone with pinfinder
help'me infinity team,i can't make boot mode in any phone .always program say: Press and HOLD Power button now !
Old 11-08-2009, 18:34   #2 (permalink)
Maiwand khan's Avatar
Member: 295886
Sonork: 100.1583369
Thanks Meter: 1,472
read carefully the Infinity-Box_PinFinder.pdf file located in
C:\Program Files\InfinityBox\Documentation\PinFinder
Old 11-08-2009, 21:48   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
before searching pinout you must do 3 easy steps:
1. Make sure that this is mt62xx MCU based phone.
tip: you can check this by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- you can be sure, that this phone is MT62xx.
Now activate Silent mode in phone by pressing and holding "#".
2. Count number of pins in system connector. After this is done-
pick correspondent cable. For example if you counted 2x6 pins- it is in total 12
so no point to put L14D cable instead of correct one, L12B.
3. Select cable type, connect power crocodiles in the place of battery.
push "Power On!" in software. Now phone is powered with pinfinder power.
Try to switch it On. This is main rule for success pinout search.
(Phone must turn ON)
if it does not turn On- no point to search for pinouts. you will not find it.
Start from modifying your main infinity box to deliver more power to pinfinder.
There is one diode which must be removed and shortcutted.
Open Pinfinder User Manual on Trubleshooting section and see in pictures how this must be done.
after you get phone powered- you are ready to find phone pinout.
press and Hold phone power button and start search.
Old 11-13-2009, 07:46   #4 (permalink)
Member: 253726
Sonork: 100 1605478
Thanks Meter: 21
still same problem with old model pinfinder
hello!
i open infinity box and diode removed also shortcutted,now read phone but can't make any operation.i tested my infinity with new model pinfinder(dark box) and work 1000%. new model pinfinder(dark box) is provided of a friend
Old 11-13-2009, 20:15   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
What was happened that your PinFinder stop to work ?
Old 11-17-2009, 16:24   #6 (permalink)
Member: 253726
Sonork: 100 1605478
Thanks Meter: 21
i have a pinfinder provided(new model) working 100%, but my pinfinder (old model) working in laptop only without charger.when connect laptop charger pinfinder can't connect any phone .maybe i can fix this problem sendme instructions please
Old 11-17-2009, 22:09   #7 (permalink)
Member: 148515
hello!
sorry, no idea. probably some power settings in your Laptop.
Old 11-19-2009, 05:32   #8 (permalink)
Member: 253726
Sonork: 100 1605478
Thanks Meter: 21
hello!
friend,pinfinder (new model)provided if it works on my laptop
Old 11-21-2009, 16:16   #9 (permalink)
Member: 148515
hello!
i really cant comment this. i never had this problem before, also noone reported this too
Can't flash any phones with usb amil0003 J.A.F. By Jafsupport.com 6 11-04-2008 10:33
box problem - can't connect any phone with usb eureka8888 Infinity-Box 8 01-08-2008 15:55
E1000: Force Boot Mode -> Phone not detected dmg2 Motorola P2k 1 01-31-2006 14:16
Pls help i can't access any phone with my computer macdan Nokia Multimedia 0 02-23-2005 21:03
Page generated in 0.19761 seconds with 9 queries
