10-23-2008, 16:31 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Location: POS
Member: 70629 Status: Offline Thanks Meter: 15 | Can't flash any phones with usb JAF version 1.98.61 Detected PKEY: 9000xxxx Card life counter: 99.97% P-key nokia module version 01.02 FBUS INTERFACE NOT CONNECTED!!! USB Cable Driver version: 7.0.2.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-222\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-222\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-222\ Scanning ini files... Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-222\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-222\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-222\rm217__04.20.mcusw PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-222\rm217__04.20.ppm_l CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-222\rm217__04.20.image_l_movca APE Variant file: NONE Languages in ppm: English,Spanish,French,Portuguese Backing up CRT... Detected P-KEY: 9000xxxx P-key nokia module version 01.02 Init usb communication... Reading IMEI... Failed! Aborting! Failed to backup CRT... Detected P-KEY: 9000xxxx P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Found Sending RAW loader... Using 06.02.002 Elf2flash 02.33.000 RAW loader... Patching RAW boot step1... Patching RAW boot step3... Sending RAW Loader... ...........Error booting phone... |
10-29-2008, 01:26 | #4 (permalink) |
No Life Poster Join Date: May 1999 Location: Thailand Age: 50
Member: 125 Status: Offline Sonork: 100.100000 Thanks Meter: 1,305 | Hi.., Download and install latest cable driver from here... http://nds1.nokia.com/files/support/..._0_2_0_eng.msi Thanks |
I can't flash 3110 phone with any version....... | amol_sm | Universalbox | 2 | 08-23-2008 16:09 |
box problem - can't connect any phone with usb | eureka8888 | Infinity-Box | 8 | 01-08-2008 15:55 |
Pls help i can't access any phone with my computer | macdan | Nokia Multimedia | 0 | 02-23-2005 21:03 |
