04-15-2009, 12:28 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 44
Member: 265133 Status: Offline Thanks Meter: 285 | Beetel Ec005 compliant was water damage dead heres the log COM7 [VCP0] selected module v2.68 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 high speed boot enabled boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #04 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #05 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #06 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #07 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: C625_BEETEL_PCB01_GSM_MT6205B_DN.KAA625A_INE_EN_HI _1_11_829.BIN ver. sw 2: KAA625A_INE_EN_HI_1.11.829, 00000000 ffs offset/size: 00300000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00300000 flash: 01227E221A2201:18E59F00000000 checking area [00000000]: 00000000-003FFFFF... eeprom/ffs found near: 00300000 detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00300000-003FFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[C625_BEETEL_PCB01_GSM_MT6205B_DN.KAA625A_INE_EN_HI _1_11_829.BIN]... file saved: E:\INFINITY\support GSMHOST\beetel eeprom[C625_BEETEL_PCB01_GSM_MT6205B_DN.KAA625A_INE_EN_HI _1_11_829.BIN]_20090414-194848.B0E.bin flash: 01227E221A2201:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 01227E221A2201:18E59F00000000 Finalization Done Finished, time used: 95 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! and then reheated cpu and set is working fine now |
The Following User Says Thank You to murthyy For This Useful Post: |
04-17-2009, 12:05 | #2 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
BEETEL EC005 by BSNL | EMOTION BBSR | Infinity-Box | 23 | 11-02-2014 18:46 |
Beetel ec005 | EMOTION BBSR | ET-BoX | 6 | 11-21-2008 17:35 |
beetel ec005 | honolulu | Infinity-Box | 1 | 08-09-2008 23:52 |
