12-24-2007, 13:35 | #1 (permalink) |
Freak Poster Join Date: Nov 2007 Location: India,Punjab,Ludhiana,Samrala
Member: 627003 Status: Offline Sonork: 100.1654163 Thanks Meter: 188 | Benq O2X1b unlock ok Device: O2X1b Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Flash: 0089:885500010001 file saved: C:\Program Files\InfinityBox\BModule\backup_eeprom-00_20071224-130523.38F.bin Check Parameters Done Check Space... Flash: 0089:885500010001 flash: Intel 28F640W30-B B 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0089:885500010001 Writing Done Finished, time used: 234 sec Remove/Install battery now ! |
01-01-2008, 20:30 | #3 (permalink) |
No Life Poster Join Date: Feb 2007 Location: india Age: 47
Member: 446363 Status: Offline Sonork: 1577571:rajtelecom Thanks Meter: 216 | COM1 [Serial0] selected Device: O2X1b Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Flash: 0089:885500010001 file saved: C:\Program Files\InfinityBox\BModule\backup_eeprom-00_20080102-005846.38F.bin Check Parameters Done Check Space... Flash: 0089:885500010001 flash: Intel 28F640W30-B B 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0089:885500010001 Writing Done Finished, time used: 43 sec Remove/Install battery now ! |
benq O2x1b dead? | kadza | Various | 4 | 05-22-2008 09:20 |
Benq M300 Flas Ok But POW Not On.....??? | SHOEB AHMED | Infinity-Box | 3 | 02-15-2008 01:14 |
O2X1b Unlock? | shahzaadbutt | FuriousGold | 8 | 09-09-2006 16:20 |
I need my O2x1b unlocked | sevans | Phone Unlocking Codes & Maps | 1 | 07-12-2006 15:29 |
O2x1b==== Unlocking. | KSM1 | Infinity-Box | 2 | 04-25-2006 10:21 |
