05-11-2008, 15:05 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Ampah, East Barito -Indonesia Age: 44
Member: 238204 Status: Offline Thanks Meter: 56 | Beyond B555 .:: Infineon e-gold ::. and found pin TX RX using Pin finder.... but I don't know how to format or flashing it... would you help me.. please Br. amien |
05-13-2008, 10:34 | #3 (permalink) | |
Member: 238204 Status: Offline Thanks Meter: 56 | Problem Resolve ! Quote:
I try using LG-KG270 (cause this model using infineon e-gold CPU too) for read flash and restting this model.. BACKUP MY FLASH Code: ==== log opened: [13/05/2008 16:14:18] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.42 S/N: ***x:***x Wait... Current model: LG KG270 Ready COM3 [VCP0] selected Device: LG KG270 Checking data, wait... Action: read flash Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check hardware... flash chip supported sw version: ULC2GL f o ' 0 !\A p ' 0 q$ Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\BAckup\beyond555\backup_eeprom-sta_20080513-161452.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\BAckup\beyond555\backup_eeprom-sec_20080513-161513.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\BAckup\beyond555\backup_eeprom-complete_20080513-161518.B1E.bin backup critical area Done Check memory... reading [flash]... file saved: C:\Program Files\InfinityBox\Pana01\BAckup\beyond555\backup_flash_20080513-161736.B1X.bin completed Finished, Remove/Install battery now ! Time used: 188 sec Code: WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM3 [VCP0] selected Device: LG KG270 Checking data, wait... Action: reset Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check hardware... flash chip supported sw version: ULC2GL f o ' 0 !\A p ' 0 q$ Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\BAckup\beyond555\backup_eeprom-sta_20080513-161836.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\BAckup\beyond555\backup_eeprom-sec_20080513-161839.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\BAckup\beyond555\backup_eeprom-complete_20080513-161845.B1E.bin reading [eeprom-dyn]... file saved: C:\Program Files\InfinityBox\Pana01\BAckup\beyond555\backup_eeprom-dyn_20080513-161849.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Write Done Finished, Remove/Install battery now ! Time used: 36 sec Maybe your box is support for this model. Br. Amien | |
How to Flash Beyond B555?? | ansarsossok | Infinity-Box | 0 | 06-06-2008 17:50 |
How to Flash Beyond B555?? | ansarsossok | Infinity-Box | 0 | 06-06-2008 12:18 |
beyond b555 errror on boot | mentari | Infinity-Box | 7 | 05-27-2008 10:32 |
Beyond B555 Can't Read Flash or any Operation | torpedo_seluler | Infinity-Box | 1 | 05-25-2008 07:11 |
beyond b555 can't boot | Andra | Infinity-Box | 1 | 05-23-2008 21:15 |
