02-28-2008, 08:15 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Indonesia Age: 43
Member: 119552 Status: Offline Thanks Meter: 33 | Beyond B610 Help!! Need Format but can not connect Use Infinity finder L12c cable. if i use power from pinfinder, phone can not power on. use bat or power supply phone can power on. But if i select Via additional harware line here's a log i f i press find it : software version: 1.06 cable type: 1x12 (L12C) platform: MT62xx (autodetect) searching adapter at COM6... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... too many retries connection w/adapter lost during set Tx as pin 3 failed to detect pins time required: 1 sec too many retries Power Off ! If use power from pinfinder can not find rx and tx. I use Usb cable from phone... Phone can read general information and here's log : Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: FYD26_05C_HW Software version: V826_ind_V09" Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 353399061031042 Finished, time used: 4 sec Power off phone now ! Then I try one by one to change rx tx with finder and find some respon if i select Rx 1 and tx 6 but cannot conect to phone. And here's log : COM6 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read eeprom Boot... Press and HOLD Power button now ! 19200 Connecting, wait... error: can't detect CPU id Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 5 sec Remove/Install battery now ! Plz Need some Advice.. BR Paedy |
02-28-2008, 17:19 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! power from adapter must be enough to find pinout even if phone can not be powered completely. please make sure that you connect power to correct terminals. pinout searching will not work if you Phone duering search is powered from power supply or battery. so, please, do once again: connect L12c to phone, connect RJ45 red wire to Positive battery terminal, black wire to negative. start search and keep power button pressed all the time while program search for pinout. Post result here |
help me beyond b21 look for network | rizkypratama999 | McnPro Box | 5 | 02-25-2010 07:45 |
help me convert beyond b630 file to infinity format | ukonxctz | Infinity-Box | 4 | 12-20-2009 22:34 |
beyond B555 , reset ok but stil locked help | alfred_smd | Infinity-Box | 3 | 11-09-2008 01:07 |
Beyond B610 detected by pinfinder | harun_warsanto | Infinity-Box | 5 | 06-27-2008 14:38 |
Is my A920 dead, beyond repairable, despritely need help? | fuji_man | Motorola P2k | 30 | 01-07-2007 09:16 |
