04-01-2010, 23:05 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 730 | Big problem with Bird s160a Here are phone backups I have maded before all operations. http://rapidshare.com/files/37089516...ckups.rar.html Can this phone be alive again? Any chance? Here are logs from every operation: Try to unlock (failed): Code: COM5 [VCP0] selected module v1.76 Device: Bird-S160 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0098:0096 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Archivos de programa\InfinityBox\Pana01\Bird-S160_eeprom-static_20100401-170849.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Archivos de programa\InfinityBox\Pana01\Bird-S160_eeprom-security_20100401-170850.B1E.bin reading eeprom-complete... file saved: C:\Archivos de programa\InfinityBox\Pana01\Bird-S160_eeprom-complete_20100401-170851.B1E.bin reading additional data... file saved: C:\Archivos de programa\InfinityBox\Pana01\Bird-S160_lock-area_20100401-170857.B1E.bin backup critical area Done Check memory ... error: unknown firmware, read flash and send to support Check memory Failed Finished, time used: 29 sec Remove/Install battery now ! Code: COM5 [VCP0] selected module v1.76 Device: Bird-S160 Checking data, wait... Action: write flash Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0098:0096 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Archivos de programa\InfinityBox\Pana01\Bird-S160_eeprom-static_20100401-172740.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Archivos de programa\InfinityBox\Pana01\Bird-S160_eeprom-security_20100401-172740.B1E.bin reading eeprom-complete... file saved: C:\Archivos de programa\InfinityBox\Pana01\Bird-S160_eeprom-complete_20100401-172741.B1E.bin backup critical area Done Check memory ... unlocking... lock found lock type #1 found operation done Check memory Done Write ... Erasing: Firmware Writing: Firmware repair write error [00400000:0800]... error: write failed[00400000] Write Failed Finished, time used: 42 sec Remove/Install battery now ! Code: COM5 [VCP0] selected module v1.76 Device: Bird-S160 Checking data, wait... Action: write flash Boot ... Press and HOLD Power button now ! error: wrong boot answer #1: Release Power button now Boot Failed Finished, time used: 36 sec Remove/Install battery now ! |
big big big big big problem with server | software zone | FuriousGold | 1 | 01-16-2008 17:25 |
big big big problem with lurker!!! | Bugytech | Wray´s Products | 9 | 11-23-2004 08:55 |
BIG BIG BIG Problem with DCT-3 and UFS3 | PhonePlus | UFS2 + UFS3-Tornadoflasher | 7 | 09-03-2004 09:50 |
BIG BIG BIG problem with SPC2 and VKLAY | wael_nasreddine | E-Gold Based Phones | 2 | 12-22-2003 22:23 |
BIG PROBLEM WITH MW3020 for BIG HACK3kr2k!!!! | sawa | Infineon C16X M51 & ARM7 M52 BASED | 8 | 11-04-2003 12:51 |
