10-26-2008, 10:54 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: P A K I S T A N(+923149818013) Age: 33
Member: 326871 Status: Offline Sonork: down2 sky.up 2 the earth Thanks Meter: 636 | Big problem.lg kg200 |
10-27-2008, 19:32 | #5 (permalink) |
Member: 326871 Status: Offline Sonork: down2 sky.up 2 the earth Thanks Meter: 636 | it was totally dead . i formatted the mobile.and for once it blinks with white screen and turns off again, |
10-27-2008, 20:18 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If phone can not power-on after flash + format there is a very big reason to check phone hardware. Also check battery voltage and press and hold phone Power button for a long time after format operation. |
10-29-2008, 20:18 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | You are wrong. If phone can not power-on after flash + format there is a very big reason to check phone hardware. Also check battery voltage and press and hold phone Power button for a long time after format operation. |
10-30-2008, 22:23 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @LOLLA If phone can not power-on after flash + format there is a very big reason to check phone hardware. You can try to use different firmware files. Also check battery voltage and press and hold phone Power button for a long time after format operation. |
11-09-2008, 18:07 | #13 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 453604 Status: Offline Thanks Meter: 33 | so no other option infact all the fone kg200 with white screen problem or displays only lg and turn off problem i could not be able to fix them by infinity i tried all the ways to format to flash to uncheck advance chip detection and smart write but never been lucky..please infinity team try to fix this bug in next update so we can do it with out chiness infinity pin finder. regards malik |
11-09-2008, 23:42 | #15 (permalink) | |
Do you understand what "bug" you talk about ? My friendly advice: always make backup before flashing, always check hardware if phone comes to you in dead condition and you will have no any "bugs". | |
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
LG kg200 auto off problem | astana2007 | LG | 21 | 10-31-2010 14:27 |
big problem with my mx key | sshreesai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-31-2010 10:07 |
6085 big problem | kami1987 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 13:42 |
big problem with lg kg195 and kg200 | sahil00150 | Infinity-Box | 3 | 03-14-2009 17:26 |
lg kg200 unlock problem | burraq | Infinity-Box | 3 | 11-16-2007 16:54 |
