10-06-2006, 23:13 | #1 (permalink) |
Freak Poster Join Date: Dec 2005
Member: 209095 Status: Offline Thanks Meter: 10 | c168 dead for unlock im try to unlock c168 by claro (brasil) after prepare step, say power up your phone adn ulock, by the fone never power up. is dead, how to solved this? |
10-07-2006, 15:00 | #3 (permalink) |
Member: 209095 Status: Offline Thanks Meter: 10 | this is teh log when unlock: COM1 selected Device: C168 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: HW ver: Check Flash Done Check Parameters... Err: this version is not supported yet. read flash and send to support Check Parameters Fail Finished Remove/Install battery now ! Time used: 12 sec Make "SP-Unlock" operation now ! |
10-07-2006, 15:15 | #4 (permalink) |
Member: 209095 Status: Offline Thanks Meter: 10 | im make this backup, send you? COM1 selected Device: C168 Checking data, wait... Action: Read flash Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: HW ver: Check Flash Done Check Parameters... Part 1 of 1... In progress... file saved: Backup_full_part_1_of_1_2006-10-7_11-13-9.69X.bin Flash: 0020:8810FFFFFFFF Finished Remove/Install battery now ! Time used: 752 sec |
10-07-2006, 20:18 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | I need to see log durun your first "prepare" operation (saved in operation.log file) what is this phone history ? is it was damaged phone when you got it ? after you give me answers we will see what to do. |
10-07-2006, 23:36 | #6 (permalink) |
Member: 209095 Status: Offline Thanks Meter: 10 | hi: thanks for a quickly answer. monday i post the log, but the phone isn not damage in the first prepare operation. i send you a full flash backup ,i hope works for you. thank again. br |
10-09-2006, 14:17 | #8 (permalink) |
Member: 209095 Status: Offline Thanks Meter: 10 | when i try flash say this: COM1 selected Device: C168 Checking data, wait... Action: Flash write Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: HW ver: Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:8810FFFFFFFF Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0020:8810FFFFFFFF Err: error flash command try to recover erase error#43 |
10-09-2006, 15:00 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | charge battery completely use latest Moto02 from support area also please check this: http://forum.gsmhosting.com/vbb/show...05&postcount=5 |
10-09-2006, 22:10 | #10 (permalink) |
Member: 209095 Status: Offline Thanks Meter: 10 | the pone is only for unlock, not damage. this is the first log, when i try prepare operation Log opened: [06/10/2006] [16:24:03] App: C:\Documents and Settings\Logicel\Escritorio\infinity\Moto02_v122\M oto02.exe Loading data, wait... [Infinity Box] v1.22 S/N: 0D1E:0108 Wait... Current model: C168 Done COM1 selected Device: C168 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: HW ver: Check Flash Done Check Parameters... Err: this version is not supported yet. read flash and send to support Check Parameters Fail Finished Remove/Install battery now ! Time used: 53 sec Make "SP-Unlock" operation now ! COM1 selected Device: C168 Checking data, wait... Action: Read flash Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... |
10-09-2006, 22:26 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, according to log: your phone can't be damaged during "prepare" operation. possible options: 1. it's not first log 2. your phone was damaged (software even can't read hw/sw version) what to do: charge battery completely use latest Moto02 from support area |
help urgently G1157 dead after unlock.. | razisamb | FuriousGold | 4 | 03-29-2010 15:38 |
need u.s.a settings for unlocked samsung s5230 for mms prepaid carrier cbw | bigmoo | Samsung Media, Games, Ringtones | 0 | 03-29-2010 13:23 |
[DOUBT] c168i = c168 for unlock | WeBoXGT | UnlockBase | 4 | 03-09-2008 11:04 |
c65 dead for unlock | Mastertronic | S-Gold Based Phones | 1 | 05-24-2005 19:15 |
help me please T191 v1.76 dead for unlock can't wake up | nanana | Motorola ODM | 1 | 08-18-2002 05:49 |
