07-22-2007, 06:02 | #1 (permalink) |
Registered User Join Date: Apr 2005 Location: niamey niger Age: 53
Member: 137207 Status: Offline Thanks Meter: 27 | C261 Formatting FTMG I juste flash C261 see step COM7 [VCP0] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C261 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.1.76 HW version: MOTOROLA_E58S LP ver: LPNA_0176 Flex ver: FLEX_90_64_4102 cpu id: 08B6 imei eeprom: 35919700035214 required SW version: 6.6.61 sp-locked: 22803. You want to write Flex in sp-locked[22803.] phone, Make this only when you understand what you want to do ! Are you sure you want to continue ? user confirmed Flex write operation for sp-locked phone Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_35919700035214_20070722-052718.34E.bin Check Flash-2 Done Write... Writing: Firmware Writing: Language Pack Writing: Flex Write Done Finished, time used: 1351 sec Remove/Install battery now ! AFTER FLASH SEE MESSAGE TO FONE ( Formatting FTMG ) now if i put sim carte the fone power on after 2second off again you see this message ( phone is hacked 68 ) pleas help I use infinity box thanks |
07-22-2007, 13:48 | #5 (permalink) | |
How about to read documentation after skipping warning messages ? Did you tried to check this: C:\Program Files\InfinityBox\Documentation | |
c261 no power done by infinity box format only | pogs1962 | Motorola Old Legacy (EMMI) | 0 | 12-08-2009 03:57 |
C261 dead error in formatting ffs | cayton_l | Infinity-Box | 1 | 07-14-2008 15:03 |
C261 no network after Format... | GsmXplorer | Infinity-Box | 4 | 02-24-2008 11:42 |
c261 formatting fmgr | c_ahmad79 | Infinity-Box | 6 | 11-15-2006 21:38 |
who can tell me how convert bin format to siemens *.xbi format? | winers | x1x to x45/x50 | 5 | 08-27-2001 19:49 |
