Old 03-14-2008, 20:42   #1 (permalink)
Medusin's Avatar
Member: 400280
Thanks Meter: 83
J100 repair erase boot failed????
I cut track and I try repair with::
DEFAULT PROTOCOL
PROTOCOL V02
PROTOCOL V06
PROTOCOL V06.2
AND THE SOFT SHOW.
COM3 selected
Device: SE J100
Checking data, wait...
Action: Flash write
Write: Repair data
Boot...
Press Power button now !
Connecting...
Boot Done
Check Connection...
Check Connection Done
Set Baud...
Set Baud Done
Check Flash...
Check Flash Done
Check Parameters...
Check Parameters Done
Check Space...
Flash: 0089:88C4
Check Space Done
Check Data...
Check Data Done
Erasing...
erase operation not required
Erasing Done
Writing...
Flash: 0089:88C4
Err: error verify
try#1 to recover write error at 00000000
Err: error verify
try#2 to recover write error at 00000000
Err: error verify
try#3 to recover write error at 00000000
Err: error verify
try#4 to recover write error at 00000000
Err: error verify
try#5 to recover write error at 00000000
Err: error verify
try#6 to recover write error at 00000000
Err: error verify
try#1 to recover write error at 00002000
Err: error verify
try#2 to recover write error at 00002000
Err: error verify
try#3 to recover write error at 00002000
Err: error verify
try#4 to recover write error at 00002000
Err: error verify
try#5 to recover write error at 00002000
Err: error verify
try#6 to recover write error at 00002000
Err: error verify
try#1 to recover write error at 00004000
Err: answer#00
try#2 to recover write error at 00004000
Err: answer#00
try#3 to recover write error at 00004000
Err: answer#00
try#4 to recover write error at 00004000
Writing Fail
Finished, time used: 55 sec
Remove/Install battery now !
HOW CAN I FIX THIS PROBLEM???
Old 03-15-2008, 21:41   #2 (permalink)
Medusin's Avatar
Member: 400280
Thanks Meter: 83
not reply from support???
Old 03-16-2008, 13:47   #3 (permalink)
green bird's Avatar
Member: 109163
Thanks Meter: 75
its cable problem, change cable or flash via anyother com
Old 03-16-2008, 16:09   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
@Medusin
What was original phone state ?
What you have tried to do with phone before repair ?
Old 03-17-2008, 23:03   #5 (permalink)
Medusin's Avatar
Member: 400280
Thanks Meter: 83
Originally Posted by InfinitySupport View Post
@Medusin
1. the original status is dead... only when I conect the cable the display show white light
2. nothing, the phone come in status DEAD.... not receive any flash and read information, I cut the track for repair data and I give the ERROR
Flash: 0089:88C4
Err: error verify
Err: error verify
Err: error verify etc etc etc
plzz how to repair??
Old 03-17-2008, 23:10   #6 (permalink)
Member: 130995
Hello,
It may be that it's not a software problem but hardware problem too.
Please, check phone hardware, clean it and probably need to reball flash chip.
Reason: flash chip is well known, phone is well known, I don't see any reason for this kind of write fault.
v3v boot a52 noflashing? no boot failed leventturksoy Smart-Clip 1 07-13-2007 19:03
Repair Dead Motorla phones with erased boot @ Infinity Box Infinity-Box Main Sales Section 0 01-15-2006 14:54
I need repair Gd 87 with erase boot sector in poland. Nestor7 Panasonic 0 05-04-2004 15:58
repairing GD52 boot erased with programmer micka22 Panasonic 2 04-26-2004 13:46
GD52: Any Solution for Erased Boot Sector? K-Dix Panasonic 20 08-05-2001 22:15
Page generated in 0.15319 seconds with 9 queries
