03-14-2008, 20:42 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: . Age: 35
Member: 400280 Status: Offline Thanks Meter: 83 | J100 repair erase boot failed???? DEFAULT PROTOCOL PROTOCOL V02 PROTOCOL V06 PROTOCOL V06.2 AND THE SOFT SHOW. COM3 selected Device: SE J100 Checking data, wait... Action: Flash write Write: Repair data Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:88C4 Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0089:88C4 Err: error verify try#1 to recover write error at 00000000 Err: error verify try#2 to recover write error at 00000000 Err: error verify try#3 to recover write error at 00000000 Err: error verify try#4 to recover write error at 00000000 Err: error verify try#5 to recover write error at 00000000 Err: error verify try#6 to recover write error at 00000000 Err: error verify try#1 to recover write error at 00002000 Err: error verify try#2 to recover write error at 00002000 Err: error verify try#3 to recover write error at 00002000 Err: error verify try#4 to recover write error at 00002000 Err: error verify try#5 to recover write error at 00002000 Err: error verify try#6 to recover write error at 00002000 Err: error verify try#1 to recover write error at 00004000 Err: answer#00 try#2 to recover write error at 00004000 Err: answer#00 try#3 to recover write error at 00004000 Err: answer#00 try#4 to recover write error at 00004000 Writing Fail Finished, time used: 55 sec Remove/Install battery now ! HOW CAN I FIX THIS PROBLEM??? |
03-17-2008, 23:03 | #5 (permalink) | |
Member: 400280 Status: Offline Thanks Meter: 83 | Quote:
1. the original status is dead... only when I conect the cable the display show white light 2. nothing, the phone come in status DEAD.... not receive any flash and read information, I cut the track for repair data and I give the ERROR Flash: 0089:88C4 Err: error verify try#1 to recover write error at 00000000 Err: error verify try#2 to recover write error at 00000000 Err: error verify etc etc etc plzz how to repair?? | |
03-17-2008, 23:10 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It may be that it's not a software problem but hardware problem too. Please, check phone hardware, clean it and probably need to reball flash chip. Reason: flash chip is well known, phone is well known, I don't see any reason for this kind of write fault. |
v3v boot a52 noflashing? no boot failed | leventturksoy | Smart-Clip | 1 | 07-13-2007 19:03 |
Repair Dead Motorla phones with erased boot @ Infinity Box | Infinity-Box | Main Sales Section | 0 | 01-15-2006 14:54 |
I need repair Gd 87 with erase boot sector in poland. | Nestor7 | Panasonic | 0 | 05-04-2004 15:58 |
repairing GD52 boot erased with programmer | micka22 | Panasonic | 2 | 04-26-2004 13:46 |
GD52: Any Solution for Erased Boot Sector? | K-Dix | Panasonic | 20 | 08-05-2001 22:15 |
