Old 03-29-2008, 12:53   #1 (permalink)
summer_20xx's Avatar
Member: 167622
Sonork: 100.1608761
Thanks Meter: 40
C707 can't access to network after flash
after flash my c707 , now it can't access to any network it just write "Emergency", when i try to find networks manually it give them to me all.
i flash it with all suggestions in the document in the support area, so now what should i do?
Old 03-29-2008, 13:16   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Is it was C707 from America ?
Old 03-29-2008, 14:24   #3 (permalink)
Member: 167622
Sonork: 100.1608761
Thanks Meter: 40
Originally Posted by InfinitySupport View Post
Hello,
no, it's from spain.
i flashed it by this flash: C707X-2ETLES1_CC36CF15_JRD26_06A_PCB01_GPRS_MT6226_S02[1].MAUI_06A_W06_52_SP1_V24_2007-08-16_En_Es_Euskera_Catalan_Galego_Movistar.B0M.bin
Old 03-29-2008, 15:07   #4 (permalink)
Member: 130995
Did you tried to make "formatt ffs" in "complete" mode ?
Old 03-29-2008, 17:33   #5 (permalink)
Member: 167622
Sonork: 100.1608761
Thanks Meter: 40
yes, but doesnt help.
btw, i flashed today two c701x succesfully, both hang on startup like c707x which we have probleme with it.
i think i need full flash for my phone
Old 03-29-2008, 18:44   #6 (permalink)
Member: 130995
How about to read instruction, read my previous message and make "format" in "complete" mode ?
Old 03-29-2008, 23:03   #7 (permalink)
Member: 167622
Sonork: 100.1608761
Thanks Meter: 40
Yes , i made "format" in "complete" mode, but the probleme is remain same.
what do u suggest now?
Old 03-30-2008, 00:16   #8 (permalink)
Member: 130995
You can flash C707 with the same C701 firmware that you have used before and that was good.
Are you sure that it's problem with phone but not problem with sim card that you have used for test ?
Is it possible to make 112 (emergency) calls from your C707 ?
Are you sure that phone is not blacklisted ?
Old 03-30-2008, 13:59   #9 (permalink)
Member: 167622
Sonork: 100.1608761
Thanks Meter: 40
my card is working well, when i try without card to call 112 the phone say "error in access", so now what to do?
p.s: how to know if my phone is blacklisted?
Old 03-30-2008, 14:26   #10 (permalink)
Member: 130995
how to know if my phone is blacklisted:
1. insert your own sim-card in phone and try to make some calls. If during nearest days police not come to you this means that phone is not blacklisted.
2. ask customer who bring you phone where he have got it.
what to do: if you are sure that phone hardware is Ok you can try to flash phone with different flash files and see results (don't forget to make "ffs format").
Did you tried to make any calls from this phone before flashing ?
What was original firmware version ?
Old 03-30-2008, 22:36   #11 (permalink)
Member: 167622
Sonork: 100.1608761
Thanks Meter: 40
No any police came to me yet, hope they will never come
The phone come to me hanging on start up logo, so i can't be sure it's working before it camed to me, second thing i think that the phone have no hardware damages because he find all available networks, the probleme can be that phone is black listed or the file i tried is from north america.
so now if i flashed the phone with an-other flash from another version will it work? second question : can i try to flash c701 files to it?
Old 03-30-2008, 23:17   #12 (permalink)
Member: 130995
Hello,
Yes, you can try to flash different files and see results. C701 files can be used too.
Old 07-09-2008, 17:14   #13 (permalink)
Member: 487753
Thanks Meter: 4
i have same problem with c701, it was hanging,but now no service after flashing.
Old 11-01-2008, 23:15   #14 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,083
About network issue in alcatel U7 models,there's a solution:
If you flashed your phone with C707X...and you get no network,then flash it with C707A and you will get network.
Also if there's no network with CxxxA (for ex C707A) just flash it with CxxxX
And If you think I helped you,hit THANKS button
ULTIMATE GSM UNLOCK
The Following User Says Thank You to jawad8305 For This Useful Post:
Old 11-02-2008, 03:13   #15 (permalink)
Member: 614097
Thanks Meter: 24
please use the M module 2.38 & Flash the c701x flash file your problem is solve But firstly check its specification phone should be support 900/1800 signal
i8510 no access to network after reset user code M_ABRISHAMI NSPRO 0 08-27-2009 10:31
Help cruiser team W220i After flashing no access to network gunjan1 Cruiser Suite 3 06-18-2008 12:01
after unlock 802se, can't access to memory stick? sanitizer Sony Ericsson 0 02-17-2006 16:20
7600 can't select non3 networks after flash alexh UFS2 + UFS3-Tornadoflasher 4 05-10-2005 12:23
Page generated in 0.22944 seconds with 9 queries
