12-01-2007, 14:17 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! yes, this chip is supported by our chinese miracle software. check with multimeter where is located GND pin and find proper pinout in our database or request here, on forum |
12-01-2007, 14:50 | #4 (permalink) |
No Life Poster Join Date: May 2006 Location: HEAVEN
Member: 285345 Status: Offline Thanks Meter: 324 | here r pinouts.............. but set is not taking any boot. not water damage also try to give some heat to cpu. with power supply it show some movement.but no boot |
12-01-2007, 15:57 | #6 (permalink) |
Member: 285345 Status: Offline Thanks Meter: 324 | I take a charging pin from a trend T100 charger. Remove cable and insert charging connector into set.battery in. I check volts with multy meter. touch black pin with gnd and found some volts on following 2 pins. other all pins not show any volt or any movement. pin no.1 is also gnd. |
12-01-2007, 18:21 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Due to a lot of different models with the same name but absolutely different hardware (f.e. exist at least 5 phones with name "Chinese Nokia-N95" but different pinouts), bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
12-02-2007, 16:27 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i think you must try this pinout: 1: Gnd 2: Tx 3: Rx 4: USB D- 5: USB D+ 6: +Vcc 7: +Vcc 8: first is gnd, next to it- tx, rx. try both ways of tx/rx |
6618 (S45 China) CAN NOT FLASH IT! Unknown Flashcode FFFF? | Joseph | x1x to x45/x50 | 6 | 02-20-2009 22:21 |
Bad flash! Can i flash it back with wotan client? | borbs | WotanServer | 1 | 09-24-2007 19:59 |
W850i OTP CID 49, flash CID 52, can i flash it or it will be locked? | Mantelis | Cruiser Suite | 13 | 09-20-2007 22:52 |
9210i version 5.33 need to change language can I flash it by any version?? | GALAXY*gsm | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 03-21-2004 15:18 |
V50 - can I flash it with flash F0_10_81-cp-lp-06.hex, with old full emmi? | sat | Motorola Old Legacy (EMMI) | 2 | 11-07-2001 06:32 |
