09-25-2008, 21:43 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If so, pls try to read flash like T250 and send flash backup file to [email protected] so we will be able to check it. |
12-19-2008, 06:39 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, How to unlock (remove sp-lock, provider lock etc.): 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software |
12-24-2008, 20:59 | #5 (permalink) |
No Life Poster Join Date: Feb 2006 Location: campioni del mondo
Member: 235881 Status: Offline Thanks Meter: 221 | unlock ok r306 Device: Sony-Ericsson-R306 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb Check hardware done Read data ... reading Sony-Ericsson-R306_eeprom_calibration-1... file saved: D:\Program Files\InfinityBox\HModule\Sony-Ericsson-R306_eeprom_calibration-1_20081223-203312.80E.bin Read data done Check data ... Check data done Write ... .............. flash: 89890400040089:89890400000000 Write: simlock Write done Finished, time used: 200 sec |
The Following 2 Users Say Thank You to GSM PAVIA For This Useful Post: |
12-25-2008, 16:46 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
01-09-2009, 21:14 | #7 (permalink) |
No Life Poster Join Date: Oct 2003 Location: South Spain
Member: 42553 Status: Offline Thanks Meter: 23 | Unlocked many R306 OK, but if you use a simcard with PIN code, the phone hangs with white display. Any way to solve this? Simcards without PIN code works OK, but.. BR |
02-20-2009, 19:39 | #8 (permalink) |
Junior Member Join Date: Jul 2006
Member: 311250 Status: Offline Thanks Meter: 1 | COM12 [VCP0] selected modulo v1.29 Servicio: Sony-Ericsson-R306 "Deteccion avanzada de chip" activado Action: unlock Checkeando datos, espere... Boot... El Telefono deberia estar APAGADO ! Presiona boton POWER Ahora ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 812500 Seleccionar velocidad done Check hardware... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb Check hardware done Read data... leyendo Sony-Ericsson-R306_eeprom_calibration-1... Archivo guardado: C:\Archivos de programa\InfinityBox\HModule\Sony-Ericsson-R306_eeprom_calibration-1_20090220-133253.80E.bin Read data done Check data... Check data done Writing... .............. flash: 89890400040089:89890400000000 Escribir: simlock Writing done Finalizado, tiempo usado: 141 sec Quite/coloque la bateria ahora ! successfully unlocking movil R306 movistar de colombia |
The Following User Says Thank You to anfel27 For This Useful Post: |
02-20-2009, 23:55 | #9 (permalink) |
Super Moderator Join Date: Jul 2008 Location: Villa del rosario/Nsd Colombia
Member: 813309 Status: Offline Thanks Meter: 1,912 | ==== log: [13/02/2009 12:32:03] ==== COM3 [VCP1] selected Device: Sony-Ericsson-T250i "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 812500 Set baud done Check hardware... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb Check hardware done Read data... reading Sony-Ericsson-T250i_eeprom_calibration-1... file saved: C:\Archivos de programa\InfinityBox\HModule\Sony-Ericsson-T250i_eeprom_calibration-1_20090213-123311.80E.bin Read data done Check data... Check data done Writing... ........................... flash: 89890400040089:89890400000000 Write: simlock Writing done Finished, time used: 70 sec Remove/Install battery now ! The Pone Is R306 Movistar Venezuela |
The Following User Says Thank You to Braycel For This Useful Post: |
08-03-2009, 13:51 | #14 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 673661 Status: Offline Thanks Meter: 349 | COM5 [VCP3] selected module v1.34 Device: Sony-Ericsson-T250i "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: EC3002FFFFFFFF:EC300200000000 flash: Samsung ST [def 0080x040000] 32Mb Check hardware done Read data ... reading Sony-Ericsson-T250i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T250i_eeprom_calibration-1_20090803-134332.80E.bin Read data done Check data ... Check data done Write ... .............. flash: EC3002FFFFFFFF:EC300200000000 Write: simlock Write done Finished, time used: 153 sec Remove/Install battery now ! but the phone is r306 movistar spain |
The Following User Says Thank You to live14 For This Useful Post: |
08-27-2009, 13:42 | #15 (permalink) |
Insane Poster Join Date: Nov 2006
Member: 384417 Status: Offline Thanks Meter: 24 | sonyericsson r306 unlock successfly with infinity COM6 [VCP0] selected module v1.35 Périphérique: Sony-Ericsson-R306 "puce de détection avancée" active Operation: déverrouiller Contrôle des données, attendre ... Boot ... téléphone doit être éteint! Appuyez sur bouton d'alimentation dès maintenant! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Ensemble bauds ... 115200 Ensemble bauds done Check hardware ... Flash 89890400040089:89890400000000 Flash Intel ST [def 0080x040000] 32Mb Check hardware done Read data ... lecture Sony-Ericsson-R306_eeprom_calibration-1... fichier sauvegardé: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-R306_eeprom_calibration-1_20090827-143306.80E.bin Read data done Check data ... Check data done écrire ... .............. Flash 89890400040089:89890400000000 écrire simlock écrire done Terminé, temps utilisé: 194 sec Retirez / remettre la batterie maintenant! |
The Following User Says Thank You to laraphone For This Useful Post: |
how to unlock SE r306 | KHAMI | SETool2 | 3 | 05-12-2010 08:17 |
can I unlock se J132 with infinity? | achi_nokia | Infinity-Box | 4 | 08-09-2009 17:35 |
Can I unlock SE R306? | Oscilloscope | Universalbox | 3 | 07-10-2009 17:31 |
How to Unlock Se K750i CID 49? Hwk can´t Unlock, Se Tool 8.4 Craked can´t unlock..... | Grupo MovilFree | Sony Ericsson | 5 | 01-18-2007 01:35 |
i have v170 from tracfon can infinity unlock this phone? | gorgans | Infinity-Box | 9 | 10-14-2005 10:25 |
