11-04-2010, 10:46 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Europe, Lemberstadt Age: 53
Member: 9889 Status: Offline Thanks Meter: 50 | 0FAA problem its 3th phone with similar problem cant read full phones are brand new from pack and different models just this log is from iphone: COM9 [VCP0] selected module v3.25 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: L071_ML_TY8A_WIFI_TV_AR_EN_THAI_V2_06 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: L071_ML_BOOTLOADER_V005_MT6235B_L071_ML_TY8A_WIFI_ TV_AR_EN_THAI_ nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: L071_ML_PCB01_GPRS_MT6235B_S01.L071_ML_TY8A_WIFI_T V_AR_EN_THAI_V2_06.BIN project-id: L071_ML_TY8A_WIFI_TV_AR_EN_THAI_V2_06, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done warning: firmware database can not be loaded area size: 32Mb number of areas/bytes to read: 1:02000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: can not read memory: 0FAA:S_FT_READBACK_FAIL can not read memory, errorcode: 0FAA it may be problem with current operation and/or future software functionality contact to support ! error: last error: 0FAA:S_FT_READBACK_FAIL Disconnect... done Finished, time used: 10 min 52 sec Remove/Install battery now ! i select 6253nor and 6228-..nand this error appears on 81% of process any idea?? |
The Following User Says Thank You to SVH For This Useful Post: |
11-04-2010, 10:53 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,989 | Hi, Please, double check that you have enough free space on your HDD (current drive and system drive). Also be sure that phone battery is enough charged (use external power supply if possible). Also it may be a problem with phone hardware (f.e. some kind of problems with flash chip, but I am not sure). |
11-04-2010, 11:01 | #3 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | 1. i have enough space 2. 4,0v enough? ext power no matter 3. maybe, but its not first phone with such error, and all phones was in good condition |
11-04-2010, 11:03 | #4 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,989 | Quote:
3. in fact I am not sure is it hw problem or not. if you have some time, please, try to read flash once again and see results. if read process stop again exactly at the same address (f.e. again and again at 811%) - I think that it's a hardware problem and software can not read more that 81% of data from flash chip. but if you will see that software stop aty different address - I think it's not a hw problem. in this case I suggest you to try to read flash at other PC and see results. | |
11-04-2010, 19:57 | #5 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | i tried on 115200 - same result, error on 81% but i think its not hw btw, this phone had restart on power i try safe format: COM9 [VCP0] selected module v3.25 Action: reset settings ("format ffs") Model: Autodetect 6253 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: L071_ML_TY8A_WIFI_TV_AR_EN_THAI_V2_06 Version: L071_08B_HW detecting structure #2... 1 2 4 5warning: wrong packet cs 8 9 11warning: wrong packet cs 12 18 19 21 22warning: wrong packet cs 25 26 28 29error: detection failed (16 tries), read flash and send to support connection Ok building list... done items to clear: 328 warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs items cleared: 328 of 328 building list... done items remains: 0 Finished, time used: 42 sec Remove/Install battery now ! passed with errors but now phone works |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
