Can not initialize test mode ! Whenever i try to connect phone by soldering wires on board(TX RX GND) i get this error. Many boards have mentioned RX TX and GND on boards but i get this error by soldering wires. If i dont connect GND then i get this error without pressing Power Button and if i connect GND then nothing happen after pressing Power Button. COM38 [VCP0] selected module v3.11 Action: reset settings ("format ffs") Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 9600 autodetect error: boot phase #2/1 failed Can not initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. ffs/eeprom is serious damaged, use repair ffs/eeprom files or use other unlock/format method error: operation failed ! Finished, time used: 4 sec Remove/Install battery now ! |
hello! you have to follow 2 rules when soldering wires to PCB. rule number 1: never forget Ground wire. Box RJ45 pin 8 must be connected with phone grounded part. rule number 2: Tx pin must be connected with pin 3, Rx with pin 2 of RJ45. in other words: box Tx must be connected with phone Rx, and otherwise box Rx with box Tx |
