09-29-2009, 13:13 | #1 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 237095 Status: Offline Thanks Meter: 0 | can not read full flash module v2.91 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [xxxxxxxxxx]... CPU: MT6225 high speed boot On chip: 0001:3203:0005 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: EC240200000000:18E59F00000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: EC240200000000:18E59F00000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation ==================== New firmware detected (v.2.91, database date: 27.08.2009): M5112_XBD_TH+EN+VI+FR+AR+RU_1KEY_3PG_A23.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info protocol ver: 04 ver. sw 1: M5112_XBD_TH+EN+VI+FR+AR+RU_1KEY_3PG_A23.BIN ver. sw 2: M5112_XBD_TH+EN+VI+FR+AR+RU_1KEY_3PG_A23, 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC240200000000:18E59F00000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00F00000 Detected ffs/eeprom address is non-standard: 00F00000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00F00000 detecting ffs/eeprom size... ffs/eeprom size: 00100000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00F00000-00FFFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: M5112_XBD_TH+EN+VI+FR+AR+RU_1KEY_3PG_A23__fullflas h... warning: wrong cs at 0x0004BC00, retry... read error recovered |
09-30-2009, 07:46 | #2 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | why you need to read full flash .......................what is the condition of phone ?....................what fault you are facing? |
09-30-2009, 12:55 | #3 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
this new flash type will be supported nearest time, as soon as arrive example of this phone. | |
11-08-2009, 10:40 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @nui I was a problem with new type of phone hardware. Please, try to use this software for flashing: http://www.infinity-box.com/download...acle_v2.97.rar It was tested with new flash chip types. Waiting for your results. |
e1110 can not read flash ,read info by z3x [Solved] | platini | Z3X-Team Products | 2 | 09-01-2009 11:30 |
Can i read full flash from broadcom? | stepanok | Samsung Flashers, Software, Firmware. | 1 | 03-31-2008 12:58 |
can HWK read full flash ?? then write back/ | ckkckk | HWK | 10 | 09-11-2005 18:14 |
How can I read full flash from my phone? | sm0lly | Mitsubishi | 18 | 09-11-2003 00:57 |
can not read @ write flash | Deltas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-20-2002 02:00 |
