11-13-2009, 22:57 | #1 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Tallinn
Member: 40082 Status: Offline Thanks Meter: 3 | can read detailed info, but can not read general info The strange thing is - I have to hold power button about 1 min, before "release power button now" sign appears (progress bar moves slowly to the end). here is the log of detailed info module v2.98 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:5941:9694 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [def 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [def 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [def 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [def 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [def 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [def 0008x004000 007Fx020000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info protocol ver: 04 ver. sw 1: H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B.BIN ver. sw 2: P02_SP_SSD_NB0_1.2.0TMC1_26B, 00000000 address offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98000300000001:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B__fullflash... file saved |
11-15-2009, 20:08 | #3 (permalink) |
Member: 40082 Status: Offline Thanks Meter: 3 | yes, phone is powered on. I was trying different modes (with SIM, without SIM) - same result. actually I don't need to read general info for this moment (phone is brand new),but I thought it could be new chip/firmware not supported by Infinity.I have seen a lot of different ChineseMiracle models - this is first time I can't read general info from totally working phone with right pin-out. Seen strange for me. |
11-15-2009, 20:44 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i think you can solve this problem like this: read out full flash and extract keyboard codes. using them access to Engeneering menu of phone and find UART options. ussually it is turned off or set to port#2. you must enable it or set to port #1 to get communcation in General mode |
J110i.. can read user code.. but can not wrong.. | bestncheap | Infinity-Box | 8 | 01-28-2010 20:55 |
i68+ i can recieved mms messages but can not send them out | matttank05 | Chinese Models & Cloned Phones | 1 | 12-30-2008 05:04 |
K808-Spreadtrum SC6600M.Find pinout ok,read full ok,but can not flash and format phon | ezzis | SpiderMan | 6 | 08-14-2008 23:41 |
N95 read ASK OK, but can`t write RPL | AndRe DCF-gsm | MT-BOX | 2 | 09-06-2007 13:25 |
DejanBOX works, but MBUS not read phone info. | MP | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 19 | 02-17-2002 15:50 |
