12-20-2007, 22:47 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: .:Planet Namek:.
Member: 189984 Status: Offline Thanks Meter: 112 | Cant change Imei on Mg320d and Mg230d... Device: LG MG320 Checking data, wait... advanced flash detection active Action: imei repair Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 98004A00000001:FEEA0000000000 flash: Toshiba AMD/Fujitsu std [B 0008x002000 00FFx010000] 16Mb id: 0000527A Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 345234523452349 file saved: backup_eeprom_345234523452349_LG MG320_20071220-164121.B1E.bin ........... version: 732-123 Check flash Done Check space... current eeprom imei: 345234523452349 Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write Done Finished, time used: 22 sec Remove/Install battery now ! -------------------- COM1 [VCP0] selected Device: LG KG320 Checking data, wait... advanced flash detection active Action: imei repair Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 98004A00000001:FEEA0000000000 flash: Toshiba AMD/Fujitsu std [B 0008x002000 00FFx010000] 16Mb id: 0000527A Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 345645675876573 file saved: backup_eeprom_345645675876573_LG KG320_20071220-164322.B1E.bin .. Check flash Done Check space... current eeprom imei: 345645675876573 Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write Done Finished, time used: 23 sec Remove/Install battery now ! -------------------------------------- COM1 [VCP0] selected Device: LG MG230 Checking data, wait... advanced flash detection active Action: imei repair Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 345456476567563 current otp imei: 011171004562423 file saved: backup_eeprom_345456476567563_LG MG230_20071220-164441.B1E.bin ............ version: utf-8, iso-8859-1, * LG-MG230 Obigo/ Check flash Done Check space... current eeprom imei: 345456476567563 Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write Done Finished, time used: 22 sec Remove/Install battery now ! after this operation the mobile have the original Imei... some solution ??? tnz in advance |
07-29-2008, 06:00 | #5 (permalink) |
Member: 189984 Status: Offline Thanks Meter: 112 | huh???? 7 months!!!! Infinity change eeprom imei in some models not external imei, the same problem on Mg280, MG110 but if flash with european firmware change imei!!!! but not network.... |
cant change imei on sony eric anymore | mehta_sajid | Universalbox | 3 | 04-07-2006 16:07 |
Cant Change Imei On Z500 <nd Z105 ? | petermobil | NSPRO | 1 | 02-24-2006 10:07 |
elco nsdongle cant change imei on X480... | cellularman | NSPRO | 0 | 02-09-2006 08:55 |
change imei on k750i and still the same imei has not change | KHEANG | MT-BOX | 4 | 12-24-2005 10:13 |
Cant change imei on E720 | roniri | TST Dongle | 4 | 08-30-2005 02:03 |
