11-28-2007, 11:57 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Due to a lot of different models with the same name but absolutely different hardware (f.e. exist at least 5 phones with name "Chinese Nokia-N95" but different pinouts), bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
11-29-2007, 14:21 | #3 (permalink) |
Temporary banned !! Join Date: Oct 2006
Member: 369992 Status: Offline Thanks Meter: 9 | the pinouts described by infinity help for cect q610 is CECT_Q610 /(18 pin) 3:GND 9:RX 10:TX but charging socket is 1*12 with 9th pin ground plz give some other solution............. |
11-30-2007, 20:29 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello pukhraj! do you have test points marked on PCB? try to connect with them. @smartengg: try again with test points marked on PCB. please note: Tx point on PCB must be connected to Rx pin on box (pin3) and otherwise Rx point on PCB must be connected to Tx pin of box (pin2) |
12-01-2007, 12:26 | #7 (permalink) | |
Member: 369992 Status: Offline Thanks Meter: 9 | Quote:
12-04-2007, 04:51 | #10 (permalink) |
Junior Member Join Date: Mar 2003 Location: india Age: 52
Member: 24217 Status: Offline Thanks Meter: 2 | N72 CECT-Q610 Pinouts Big Problem Hello Infinity Supporter CECT Q610 (Market N72 On Screen) 1.......12 {.............} Pinout Marked on pcb not work pls tell correct pinouts |
12-04-2007, 13:09 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! did you try to swap wires on PCB pinout? because like i told already phone Tx must go to box Rx and otherwise phone RX to box Tx. some of users connect Tx to Tx, Rx to Rx- that is why cable is not working |
01-20-2008, 19:40 | #14 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: India Age: 46
Member: 129258 Status: Offline Thanks Meter: 105 | Quote:
Dear please see phone motherboard first this phone is not mtk this is infinion so infinity not support this your pinout is right but no support of this processer so you cant do with infinity Aruna Export | |
Cect Q610 Copy Of N72 Infinieon Chip Dead | shripalkawdia | SpiderMan | 3 | 05-29-2008 07:57 |
plz help me i need cect q610 12pin pinout | bharat982779950 | Infinity-Box | 3 | 12-23-2007 05:04 |
hi all i have cect q610 small n72 chnese | unlock_solution | Infinity-Box | 1 | 11-14-2007 16:55 |
cect q610 pe calibration problame | sachin_udai | Infinity-Box | 1 | 09-20-2007 20:26 |
Cect Q610 Pinout Need | kabirhossain | Infinity-Box | 1 | 04-27-2007 17:41 |
