02-02-2008, 09:04 | #1 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 194285 Status: Offline Thanks Meter: 53 | cect t888 restart with sim taken full flash back up done format ffs after that display going white with sound on-off comming what to do not geting flash file in support site here is log COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:8041:73C0 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: E728_PCB01_GPRS_MT6226_S01.M22M019B0606_5_3_1_2D08 01C03.BIN ver. sw2: M22M019B0606.5.3.1.2D0801C03, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF reading [flash[E728_PCB01_GPRS_MT6226_S01.M22M019B0606_5_3_1_2D08 01C03.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_flash[E728_PCB01_GPRS_MT6226_S01.M22M019B0606_5_3_1_2D08 01C03.BIN]_20080201-222351.B0M.bin Finished, time used: 335 sec Remove/Install battery now ! COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:8041:73C0 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: E728_PCB01_GPRS_MT6226_S01.M22M019B0606_5_3_1_2D08 01C03.BIN ver. sw2: M22M019B0606.5.3.1.2D0801C03, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF flash: EC257E25082501:2AEA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: EC257E25082501:2AEA0000000000 Write Done Finished, time used: 52 sec Remove/Install battery now ! |
02-02-2008, 10:16 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: France Age: 48
Member: 165812 Status: Offline Sonork: 100:1627635 Thanks Meter: 4,267 | try to do complete format ffs if the phone stay with restart with sim inside ty to call 112 without sim card if it is turn off then it is hardware problem . |
02-03-2008, 05:52 | #9 (permalink) |
Member: 194285 Status: Offline Thanks Meter: 53 | tryed both safe format and also tryed complite format also result is same -->white display. restored backup then did format with a simple tool now phone working fine no restart and no white display |
12-16-2008, 10:10 | #10 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: Gsmhosting Age: 42
Member: 138809 Status: Offline Sonork: 100.99886 Thanks Meter: 79 | Quote:
plz if u can share its backup , or how u solved ur problem plz share thanks in advance | |
12-16-2008, 19:28 | #11 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
probably program made eeprom backup while formating this set? if yes- you can restore it and return phone to original state after that try safe format | |
03-18-2009, 09:21 | #14 (permalink) |
Member: 138809 Status: Offline Sonork: 100.99886 Thanks Meter: 79 | http://rapidshare.com/files/21060198...10C08.rar.html here is readout orignal bakup got from my friend but its not in infinity format , infinity team can u plz convert it thanks |
CECT v808 bluethoot restarting with sim | oneboy | Chinese Models & Cloned Phones | 3 | 04-02-2009 02:17 |
Cect t689 restart with sim card | F@RUK S | Infinity-Box | 7 | 09-17-2008 21:50 |
cect K808 2sim restart with sim | farshid-jan | Infinity-Box | 7 | 12-27-2007 10:44 |
How to reapair restart with sim card, N95 with 2 sim? | .:RAGE:. | Infinity-Box | 13 | 11-30-2007 14:56 |
GD87 works fine without SIM, restarts with SIM | seth_ro | Panasonic | 9 | 11-23-2005 17:42 |
