CF61 dead after flashing After flashing phone is dead, I have made full backqup from phone before flashing also eeprom readed this is log below, everything went OK Infinity please help to review this phone. B.R. Windziarz COM6 selected Device: BenQ CF61 Checking data, wait... Action: Flash write Smart Write active Write: Firmware Skip: Flex Write: Language Pack Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 203125 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:881500010001 flash: Intel 128MBit-B Strata B 16Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:881500010001 flash: Intel 128MBit-B Strata B 16Mb Flash: 0089:881500010001 flash: Intel 128MBit-B Strata B 16Mb Write: Language Pack flash: Intel 128MBit-B Strata B 16Mb Writing Done Finished, time used: 1427 sec Remove/Install battery now ! |
I have the same I tell about this few week ago but infinity support nothing do !! !! Current model: BenQ CF61 COM4 ready Loading file v.02... CF61_Main_v103.90M.bin Loaded Loading file v.02... CF61_LP_v103_0022_En_De_Pl_Ee_Lv_Lt_Ru_Ukr.90P.bin Loaded COM4 selected Device: BenQ CF61 Checking data, wait... Action: Flash write Smart Write active Write: Firmware Skip: Flex Write: Language Pack Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Try to use slow speed Set Baud Fail Finished, time used: 18 sec Remove/Install battery now ! COM4 selected Device: BenQ CF61 Checking data, wait... Action: Flash write Smart Write active Write: Firmware Skip: Flex Write: Language Pack Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 406250 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:881500010001 flash: Intel 128MBit-B Strata B 16Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:881500010001 flash: Intel 128MBit-B Strata B 16Mb Flash: 0089:881500010001 flash: Intel 128MBit-B Strata B 16Mb Write: Language Pack flash: Intel 128MBit-B Strata B 16Mb Writing Done Finished, time used: 1147 sec Remove/Install battery now ! I try write repair eeprom and this not do nothing !! !! Loading file v.02... CF61_repair_eeprom_01.90E.bin Loaded COM4 selected Device: BenQ CF61 Checking data, wait... Action: Flash write Smart Write active Skip: Firmware Skip: Flex Skip: Language Pack Skip: Eeprom Err: no data to write ! COM4 selected Device: BenQ CF61 Checking data, wait... Action: Flash write Smart Write active Skip: Firmware Skip: Flex Skip: Language Pack Write: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 406250 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:881500010001 flash: Intel 128MBit-B Strata B 16Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Eeprom Flash: 0089:881500010001 flash: Intel 128MBit-B Strata B 16Mb Writing Done Finished, time used: 133 sec Remove/Install battery now ! and this Loading file v.02... CF61_repair_eeprom_02.90E.bin Loaded COM4 selected Device: BenQ CF61 Checking data, wait... Action: Flash write Smart Write active Skip: Firmware Skip: Flex Skip: Language Pack Write: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 406250 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:881500010001 flash: Intel 128MBit-B Strata B 16Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Eeprom Flash: 0089:881500010001 flash: Intel 128MBit-B Strata B 16Mb Writing Done Finished, time used: 149 sec Remove/Install battery now ! I fix phone with fullflash and with vygis software after write fullflash phone work without problem but with infinity can't fix this phone !! !! !! |
Readed flash with problem description sended to support, hope solution will come realy fast. B.R. for Infinity Team |
Hi, New files uplaoded in support area: CF61_Main_v102 CF61_LP_v102_0001_De_It_Fr_Es_Pt_Catala_PtBr CF61_repair_eeprom_03 CF61_repair_eeprom_04 try to flash phone with these files and let me know about results. |
surely I'll post results, thanks for fast reply. B.R. for Infinity Team |
what to do next? Loading file v.02... CF61_Main_v102[1].90M.bin Loaded Loading file v.02... CF61_LP_v102_0001_De_It_Fr_Es_Pt_Catala_PtBr[1].90P.bin Loaded Loading file v.02... CF61_repair_eeprom_03[1].90E.bin Loaded COM6 selected Device: BenQ CF61 Checking data, wait... Action: Flash write Write: Firmware Skip: Flex Write: Language Pack Write: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 406250 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:881500010001 flash: Intel 128MBit-B Strata B 16Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:881500010001 flash: Intel 128MBit-B Strata B 16Mb Flash: 0089:881500010001 flash: Intel 128MBit-B Strata B 16Mb Write: Language Pack flash: Intel 128MBit-B Strata B 16Mb Write: Eeprom flash: Intel 128MBit-B Strata B 16Mb Writing Done Finished, time used: 1433 sec Remove/Install battery now ! Loading file v.02... CF61_repair_eeprom_04[1].90E.bin Loaded COM6 selected Device: BenQ CF61 Checking data, wait... Action: Flash write Skip: Firmware Skip: Flex Skip: Language Pack Write: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 406250 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:881500010001 flash: Intel 128MBit-B Strata B 16Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Eeprom Flash: 0089:881500010001 flash: Intel 128MBit-B Strata B 16Mb Writing Done Finished, time used: 141 sec Remove/Install battery now ! |
bro please help me to unlock BENQ SIEMENS A38 with infinity |
Folow the instruction from support all should be fine |
now let's back to the topic 1. tried to flash with flashes from support - phone dead 2. when I restored backup - phone ok 3. when I flashed lang package only - phone shows only "Please Download Language Pack" message 4. I'll try to flash with original update utility to version 1.13 and then flash only LP and post results here Infinityteam - do you have any ideas how to fix it? I have good piece for tests (backup read so no risk and I can make as many tries as needed) BR |
@ceedee @Windziarz BModule v1.27 uploaded in support area in "beta/test software" section. Pls, try it and let me know about results. Don't forget to make "smart write" option checked for faster operation. |
Code: COM5 selected BR |
new version works ok, so all users with phones dead after flash with current official version pls wait for official BModule update - tested by Windziarz and me with CF61* and files from support BR *now is correct :) |
to be more precise CF61 :) Today I should have S88 with Polish lang so expect update of flash files on support area :) B.R. Windziarz |
Please help with CF61 HI, the phone came to me with the problem of no delating files? i started flashing and the result the phone is dead, but can connect with software, here is the log COM2 selected Device: BenQ CF61 Checking data, wait... Action: Flash write Write: Firmware Skip: Flex Write: Language Pack Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 406250 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:881500010001 flash: Intel 128MBit-B Strata B 16Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:881500010001 flash: Intel 128MBit-B Strata B 16Mb Err: answer#00 try#1 to recover erase error#00 Err: answer#00 try#2 to recover erase error#00 Err: answer#00 try#1 to recover write error at 00000000 Err: error flash timeout try#2 to recover write error at 00000000 Err: flash end try#3 to recover write error at 00000000 Err: error flash timeout try#4 to recover write error at 00000000 Err: flash end try#5 to recover write error at 00000000 Err: error try#6 to recover write error at 00000000 Err: answer#00 try#1 to recover write error at 00002000 Writing Fail Finished, time used: 50 sec Remove/Install battery now ! Any solution ??? |
