06-03-2009, 14:16 | #1 (permalink) |
No Life Poster Join Date: May 2007 Age: 42
Member: 501674 Status: Offline Sonork: THEIF OF HEART Thanks Meter: 883 | chaina mobile dead after ffs complete format here is log . COM4 [VCP0] selected module v2.82 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! error: boot initialization step #2 failed: 5F error: boot initialization step #2 failed: 5F error: boot initialization step #3 failed: 5F error: boot initialization step #3 failed: 00 error: boot initialization step #3 failed: 00 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #2 failed: A0 error: boot initialization step #3 failed: A0 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001803:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 230400 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. G:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. G:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: EC257E25082501:FFFFFF00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC257E25082501:FFFFFF00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:FFFFFF00000000 Finalization Done Finished, time used: 129 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ..::S@JID::.. |
06-03-2009, 23:07 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you provided logs of already dead phone. there we cant see its original software version. can you find very first log, where we can find this? all logs is stored in operation.log file |
06-06-2009, 08:48 | #4 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Nashik
Member: 578632 Status: Offline Thanks Meter: 229 | bro, here i can see in ur post ur firmware and eepron file are missing in ur mobile so u need to download flash file from support area and flash it, plz rember before complet format u must read full flash file or phone info., then do complet formatting.. here i m not getting any flash file version information in ur post. if u can upload pcb+phone+model photo then i can help u in this matter... Last edited by rajmobile123; 06-06-2009 at 08:53. |
chaina phone dead after format by using infinity Box | MANfaith | Chinese Models & Cloned Phones | 9 | 09-06-2009 08:38 |
Siroya please hellpme f275l dead after ffs format | soulcelulares | UST Pro II | 2 | 07-16-2009 16:31 |
fly 2040 dead after ffs | singhdeep | Infinity-Box | 10 | 12-23-2008 17:25 |
Cect Lv-918 Dead After Ffs | Parminder Singh | Infinity-Box | 4 | 03-26-2008 05:59 |
China Mobile Dead After Format | aukonline | Infinity-Box | 2 | 03-04-2008 16:14 |
