12-18-2010, 13:49 | #1 (permalink) |
Freak Poster Join Date: Jul 2003 Location: Lithuania,Kaunas Age: 48
Member: 33166 Status: Offline Thanks Meter: 4 | SCi iphone i9+++ which flash use to flash phone? COM5 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:2C03:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 89887E00040004:89887E00000000 flash: 89887E00040004:89887E00000000 flash: Intel 512MBit non-mux U 64Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 89887E00040004:89887E00000000 flash: 89887E00040004:89887E00000000 flash: Intel 512MBit non-mux U 64Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 total flash region size: 04000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 03C00000 flash: 89887E00040004:89887E00000000 flash: 89887E00040004:89887E00000000 checking area [00000000]: 00080000-03FFFFFF... ffs/eeprom found near: 01D40000 Detected ffs/eeprom address is non-standard: 01D40000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 01D40000 detecting ffs/eeprom size... ffs/eeprom size: 022C0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01D40000-03FFFFFF firmware area: 00000000-01D3FFFF detecting ffs/eeprom structure pass 1... .................................................. .................................................. ................. ffs/eeprom: can't detect record name location error: ffs/eeprom detection failed: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... .................................................. .................................................. .................................................. .................................................. .................................................. ...... .................................................. .................................................. .................................................. .................................................. .................................................. ...... done warning: can not detect firmware version if software freez: make "Find firmware version (slow process)" unchecked and repeat operation. detecting firmware build... .................................................. ............................................ done detecting product-id... .................................................. .................................................. .................................................. .................................................. .................................................. ...... done detecting languages... .................................................. ....................... ... language parameters detected warning: can not detect language names if software freez: make "Find language names (slow process)" unchecked and repeat operation. Finished, time used: 4 min 13 sec Remove/Install battery now ! Thanks in advance |
12-18-2010, 16:16 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! can you disassemble this phone and look for printed short code version on PCB? it is usually located near or under LCD. telling us this short code would help us alot |
12-20-2010, 20:49 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! unfortunately, this isnt helpful at all... try to make search for "i9+++" on our support server and try all available different version flash files. I dont see any other way now |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
