09-24-2008, 16:10 | #1 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Sigmatel T99 flashing Problem.... I try to flash one T99 but it show this error. Code: COM11 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:E203:000B boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer: wrong answer after chip id request number of flash chip/regions detected: 00/01 Unknown or damaged flash chip, operation aborted. Fault reasons: 1. damaged flash chip: replace or resolder/reball flash chip 2. damaged hardware: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 31 sec Remove/Install battery now ! |
The Following User Says Thank You to amol_sm For This Useful Post: |
09-24-2008, 18:31 | #2 (permalink) | |
Member: 343326 Status: Offline Thanks Meter: 1,463 | Infinity Team, I solve my problem by heating flash chip. And in that handset new version is detected. here is more detail info. Quote:
File sent to [email protected] Thankx Infinity Team. | |
09-24-2008, 22:32 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you worked with second MCU. if you still have problem with your phone- try to format first MCU |
09-25-2008, 05:47 | #4 (permalink) |
Member: 343326 Status: Offline Thanks Meter: 1,463 | Second CPU...... I don't understand what do u mean... In this board only one CPU & another one is flash chip. Also i don't find any second cpu pinout for this phone.... Also i tell u that it is not dual sim card phone it is only single. |
09-27-2008, 22:17 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! sorry, i missuderstoode you. got your email, it will be processed asap thnk you for your help! |
sigmatel t99 strange problem after flash | drjaved_akhter | Infinity-Box | 4 | 10-13-2009 21:40 |
SIGMATEL T99 flash files Needed | Faheem Anjum | SpiderMan | 0 | 08-18-2009 12:57 |
SIGMATEL T99 flash files Needed | Faheem Anjum | SpiderMan | 0 | 08-18-2009 12:48 |
sigmatel t99 software problem | ayaz_hasham | Chinese Models & Cloned Phones | 5 | 10-25-2008 21:47 |
sigmatel t99 software problem | ayaz_hasham | Chinese Models & Cloned Phones | 0 | 10-18-2008 10:37 |
