Old 09-24-2008, 16:10   #1 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Sigmatel T99 flashing Problem....
Hello to all,
I try to flash one T99 but it show this error.
COM11 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read NOR flash
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:E203:000B
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
error: no any expected answer
error: no any expected answer: wrong answer after chip id request
error: no any expected answer: wrong answer after chip cfi request
number of flash chip/regions detected: 00/01
Unknown or damaged flash chip, operation aborted.
Fault reasons:
1. damaged flash chip: replace or resolder/reball flash chip
2. damaged hardware: check hardware, water inside etc.
3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again
4. wrong model selection, try 'NAND' selection
Initialize Fail
Finished, time used: 31 sec
Remove/Install battery now !
Phone is hang problem. I complete Format FFS but not done. & in this phone new version is detected i can't read full flash.
The Following User Says Thank You to amol_sm For This Useful Post:
Old 09-24-2008, 18:31   #2 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Infinity Team,
I solve my problem by heating flash chip. And in that handset new version is detected. here is more detail info.
Sw V - VT25_06B_V506HX_PCB01_GPRS_MT6225_S00.V506HX_SAM_S ET100A_9320_V1_8.BIN
Beand - Sigmatel
Model T99
File sent to [email protected]
Thankx Infinity Team.
Old 09-24-2008, 22:32   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
you worked with second MCU.
if you still have problem with your phone- try to format first MCU
Old 09-25-2008, 05:47   #4 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Second CPU......
I don't understand what do u mean... In this board only one CPU & another one is flash chip.
Also i don't find any second cpu pinout for this phone.... Also i tell u that it is not dual sim card phone it is only single.
Old 09-27-2008, 22:17   #5 (permalink)
Member: 148515
hello!
sorry, i missuderstoode you.
got your email, it will be processed asap
thnk you for your help!
sigmatel t99 strange problem after flash drjaved_akhter Infinity-Box 4 10-13-2009 21:40
SIGMATEL T99 flash files Needed Faheem Anjum SpiderMan 0 08-18-2009 12:57
SIGMATEL T99 flash files Needed Faheem Anjum SpiderMan 0 08-18-2009 12:48
sigmatel t99 software problem ayaz_hasham Chinese Models & Cloned Phones 5 10-25-2008 21:47
sigmatel t99 software problem ayaz_hasham Chinese Models & Cloned Phones 0 10-18-2008 10:37
Page generated in 0.16684 seconds with 9 queries
