12-06-2009, 16:22 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | china n82 when change video phone goes to off & restart plz help infinity team & here is read flash & format log ==== log: [12/6/2009 9:12:42 PM] ==== COM5 [VCP0] selected module v3.01 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 3 sec Remove/Install battery now ! ==== log: [12/6/2009 9:13:10 PM] ==== COM5 [VCP0] selected module v3.01 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0000:0000:0000 status: AA error: initialize step #1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 23 sec Remove/Install battery now ! ==== log: [12/6/2009 9:13:46 PM] ==== COM5 [VCP0] selected module v3.01 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1941:AD94 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.EDFA4BDA.[MT6226_07B_GEMINI_PCB01_GPRS_MT6226_S01.N82_00A_V1 _00.BIN_0E3E79BC].rpl ==================== New firmware detected (v.3.01, database date: unknown): MT6226_07B_GEMINI_PCB01_GPRS_MT6226_S01.N82_00A_V1 _00.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: EDFA4BDA rom info protocol ver: 04 ver. sw 1: MT6226_07B_GEMINI_PCB01_GPRS_MT6226_S01.N82_00A_V1 _00.BIN ver. sw 2: N82_00A_V1.00, BC793E0E code offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: MT6226_07B_GEMINI_PCB01_GPRS_MT6226_S01.N82_00A_V1 _00__fullflash... file saved: C:\Documents and Settings\MOHIUDDIN\Desktop\MT6226_07B_GEMINI_PCB01 _GPRS_MT6226_S01.N82_00A_V1_00__fullflash_20091206-214301.B0M.bin file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M T6226_07B_GEMINI_PCB01_GPRS_MT6226_S01.N82_00A_V1_ 00__system_log_EDFA4BDA_0E3E79BC_20091206-214402.B0X.bin Finished, time used: 1813 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [12/6/2009 9:44:21 PM] ==== COM5 [VCP0] selected module v3.01 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:1941:AD94 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.EDFA4BDA.[MT6226_07B_GEMINI_PCB01_GPRS_MT6226_S01.N82_00A_V1 _00.BIN_0E3E79BC].rpl ==================== New firmware detected (v.3.01, database date: unknown): MT6226_07B_GEMINI_PCB01_GPRS_MT6226_S01.N82_00A_V1 _00.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: EDFA4BDA rom info protocol ver: 04 ver. sw 1: MT6226_07B_GEMINI_PCB01_GPRS_MT6226_S01.N82_00A_V1 _00.BIN ver. sw 2: N82_00A_V1.00, BC793E0E code offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: MT6226_07B_GEMINI_PCB01_GPRS_MT6226_S01.N82_00A_V1 _00__ffs... file saved: C:\Documents and Settings\MOHIUDDIN\Desktop\MT6226_07B_GEMINI_PCB01 _GPRS_MT6226_S01.N82_00A_V1_00__ffs_20091206-214848.B0E.bin flash: 01227E22202200:29EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M T6226_07B_GEMINI_PCB01_GPRS_MT6226_S01.N82_00A_V1_ 00__system_log_EDFA4BDA_0E3E79BC_20091206-214910.B0X.bin Finished, time used: 287 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! plz help needed its urgent. |
12-07-2009, 17:34 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! flashing must be done now, but looks like this is very rare or new firmware. unfortunately we dont have it in our collection. you can try to search for same working phone on local market. read out full backup and use it for flashing your faulty phone. also i can convert to infinity format BIN file, if you find it. |
infinity box not working plz help infinity team | Y2ksalman | Infinity-Box | 21 | 01-18-2011 00:51 |
china dual sim imei problem plz help infinity team ! | mbiborna | Infinity-Box | 3 | 11-30-2009 14:03 |
cant open infinity shell plz help infinity team | ali_imran | Infinity-Box | 27 | 06-14-2008 20:01 |
i try flyslt100 unlocking with infinity but phone dead plz help infinity team | qaziomer | Infinity-Box | 4 | 03-30-2008 19:43 |
Plz Help Infinity Team | rajan nishchal | Infinity-Box | 5 | 02-27-2007 19:14 |
