01-04-2011, 11:35 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Age: 45
Member: 93284 Status: Offline Thanks Meter: 202 | China N95 8GB read flash problem Here are some screenshots and settings I use. and here is log Code: ==== [2011-01-04 10:23:22] ==== COM3 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read firmware ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:0403:000B status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... slowest Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: N95_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12.BIN project-id: MAUI.GEMINI.W08.12, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: N95_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12__firmware_part_1_of_1... warning: wrong data size at 0x004CB800, retry... warning: wrong data size at 0x004CB800, retry... warning: wrong data size at 0x004CB800, retry... warning: wrong data size at 0x004CB800, retry... warning: wrong data size at 0x004CB800, retry... warning: wrong data size at 0x004CB800, retry... warning: wrong data size at 0x004CB800, retry... warning: wrong data size at 0x004CB800, retry... warning: wrong data size at 0x004CB800, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? aborted by user file saved: C:\Documents and Settings\rosta\Pulpit\N95_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12__firmware_part_1_of_1_20110104-105231.B0M.bin Finished, time used: 28 min 58 sec Remove/Install battery now ! Code: ==== [2011-01-03 16:02:50] ==== COM3 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:0403:000B status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... slowest Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: N95_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12.BIN project-id: MAUI.GEMINI.W08.12, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: N95_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12__fullflash... warning: wrong data size at 0x0033A000, retry... warning: wrong data size at 0x0033A000, retry... warning: wrong data size at 0x0033A000, retry... warning: wrong data size at 0x0033A000, retry... warning: wrong data size at 0x0033A000, retry... warning: wrong data size at 0x0033A000, retry... warning: wrong data size at 0x0033A000, retry... warning: wrong data size at 0x0033A000, retry... warning: wrong data size at 0x0033A000, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? aborted by user file saved: C:\Program Files\InfinityBox\ChineseMiracle\N95_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12__fullflash_20110103-162625.B0M.bin Finished, time used: 23 min 38 sec Remove/Install battery now ! BR |
01-05-2011, 12:17 | #3 (permalink) |
Member: 93284 Status: Offline Thanks Meter: 202 | Hi Sorry but it was my laptop problem. On other PC everything working fine. Strange is that I read fullflash before on this laptop from Alcatel and it was fine If somebody need pinout of such pcb here it is. BR |
The Following User Says Thank You to owiec77 For This Useful Post: |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Eeprom reading | KLImax | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-22-2011 15:55 |
