09-12-2008, 18:30 | #1 (permalink) |
No Life Poster Join Date: Jan 2006
Member: 219015 Status: Offline Thanks Meter: 42 | Chines Miracle N15 can't fix touchscreen calibration Code: ==== log: [12.09.2008 16:59:02] ==== COM3 [Serial2] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:87DA:5867 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT Version: SWAN_6226 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-1)... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19error: detection failed (20 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 87 sec Remove/Install battery now ! ==== log: [12.09.2008 17:01:01] ==== COM3 [Serial2] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:87DA:5867 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT Version: SWAN_6226 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-2)... 1 2 3 4 5 6 7 8 9 10 11 done 146 byte(s) read reading data#2... reading data#3... error: operation failed ! Finished, time used: 46 sec Remove/Install battery now ! ==== log: [12.09.2008 17:01:59] ==== COM3 [Serial2] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:87DA:5867 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT Version: SWAN_6226 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-3)... done 158 byte(s) read writing data... verification... error: verification failed Finished, time used: 18 sec Remove/Install battery now ! Code: ==== log opened: [12.09.2008 17:31:55] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.exe Loading data, wait... [Infinity Box] v2.59 S/N: 0F4A:0110 Wait... Device: Autodetect 6205-6227 NOR Done Loading file v.02... CM_Nokia-E86-2sim_CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT_16m_En_Ru_Fr_Th_Vn_Farsi_Ar.B0M.bin loaded identification#1 protocol ver: 04 ver. sw1: CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT.BIN ver. sw2: SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT, 435B322F You have loaded file with security features enabled. detecting languages... Languages: En Ru Fr Th Vn Farsi Ar ==== log: [12.09.2008 17:34:00] ==== COM3 [Serial2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:87DA:5867 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22212200:2CEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22212200:2CEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22212200:2CEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22212200:2CEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.1946A263.[CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT.BIN_D0CDA4BC].rpl identification#1 detection finished device-id: 1946A263 identification#1 protocol ver: 04 ver. sw1: CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT.BIN ver. sw2: SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT, 435B322F ffs offset/size: 00F00000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00F00000 flash: 01227E22212200:2CEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT.BIN]_20080912-173646.B0E.bin flash: 01227E22212200:2CEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished security area#1 calculation... done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_1946A263_CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT.BIN_D0CDA4BC_20080912-173705.B0X.bin Area: Firmware flash: 01227E22212200:2CEA0000000000 Write: Firmware detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_1946A263_CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT.BIN_D0CDA4BC_20080912-173715.B0X.bin Finished, time used: 175 sec Remove/Install battery now ! Code: ==== log: [12.09.2008 17:38:04] ==== COM3 [Serial2] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:87DA:5867 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT Version: SWAN_6226 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-2)... 1 2 3 4 5 6 7 8 9 10warning: wrong packet cs 11 done 172 byte(s) read reading data#2... reading data#3... error: operation failed ! Finished, time used: 51 sec Remove/Install battery now ! ==== log: [12.09.2008 17:39:04] ==== COM3 [Serial2] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:87DA:5867 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT Version: SWAN_6226 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-3)... done 158 byte(s) read writing data... verification... error: verification failed Finished, time used: 17 sec Remove/Install battery now ! Code: ==== log: [12.09.2008 17:40:41] ==== COM3 [Serial2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:87DA:5867 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22212200:2CEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22212200:2CEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22212200:2CEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22212200:2CEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.1946A263.[CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT.BIN_D0CDA4BC].rpl identification#1 detection finished device-id: 1946A263 identification#1 protocol ver: 04 ver. sw1: CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT.BIN ver. sw2: SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT, 435B322F ffs offset/size: 00F00000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00F00000 flash: 01227E22212200:2CEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT.BIN]_20080912-174216.B0E.bin flash: 01227E22212200:2CEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished security area#1 calculation... done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_1946A263_CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT.BIN_D0CDA4BC_20080912-174227.B0X.bin Area: Firmware flash: 01227E22212200:2CEA0000000000 Write: Firmware detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_1946A263_CKT26_06B_PCB01_GPRS_MT6226_S01.SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT.BIN_D0CDA4BC_20080912-175014.B0X.bin Finished, time used: 567 sec Remove/Install battery now ! Code: ==== log: [12.09.2008 17:51:07] ==== COM3 [Serial2] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:87DA:5867 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: SWAN+_6226_YTCQYR_L7EN_227_071106_LD0_0V0_SA75_CTF_BT Version: SWAN_6226 detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-3)... done 158 byte(s) read writing data... verification... error: verification failed Finished, time used: 18 sec Remove/Install battery now ! |
09-13-2008, 19:32 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if all methods to bypass touchscreen calibration failed- read out full flash and post here as www.rapidshare.com link |
Bypass damaged Touchscreen calibration solution... | InfinitySupport | Infinity-Box | 223 | 10-28-2010 16:51 |
<<< Chinese Miracle 2.91 Touchscreen Calibration Improvement >>> | khadim100 | Infinity-Box | 1 | 10-02-2009 07:33 |
<<< Chinese Miracle 2.91 Touchscreen Calibration Improvement >>> | khadim100 | Infinity-Box | 0 | 09-30-2009 17:02 |
Can't Remove touchscreen calibration | R@ZIB-BD | Infinity-Box | 7 | 07-08-2009 08:47 |
