03-23-2014, 15:41 | #16 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Nokia 210 RDA 8851 8mb(test report) READ INFO Code: Operation : Check Device / Info ======= Settings Settings : Read AllInfo is On Settings : Full Boot disabled by default Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1700 FL_CNM : GigaDevice , GD25Q64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Use : 8809_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Elapsed: 00:00:05 Done Reconnect Power/Cable! READ USER CODE Code: Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1700 FL_CNM : GigaDevice , GD25Q64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Use : 8809_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read done, sorting EXTData Following items found : Item : NVRAM Required data found, extracting code UserCode : 1234 Elapsed: 00:00:58 Done Reconnect Power/Cable! REPAIR IMEI Code: Operation : Factory Area Rebuild [Repair IMEI] Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1700 FL_CNM : GigaDevice , GD25Q64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Use : 8809_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Factory Sector ... Read Ok , verify Detected 2 Sim Slot(s) Current Phone IMEI : IMEI1 : 357343055685963 IMEI2 : 357343055685971 New Phone IMEI : IMEI1 : 35001122336655-3 IMEI2 : 35002255669887-6 Build Factory Sector Write Factory Sector CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Verify Factory Sector Sector Verifyed! IMEI Write Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
The Following 6 Users Say Thank You to saeedullah_khan For This Useful Post: |
03-23-2014, 16:01 | #17 (permalink) | |
It's unsupported hardware, we will try to update software ASAP. | |
03-23-2014, 16:01 | #18 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
The Following User Says Thank You to Dzirt For This Useful Post: |
03-23-2014, 16:23 | #19 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Nokia 210 RDA 8851 8mb(test report) Nokia 210 RDA 8851 8mb(test report) READ FLASH DONE (8MB) Read Flash Time Elapsed: 00:36:01 Takes too much time Code: Operation : Format File System Settings : SmartFormat is Off Com Port Opened Press and hold POWER button! Waiting phone Error on boot , check cable, try again Reconnect Power/Cable! Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1700 FL_CNM : GigaDevice , GD25Q64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Use : 8809_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Flash now ... Read Ok, 8388608 bytes read Verify file... Target BbCpu : CT8851E Target Flash : flsh_spi64m Project Name : test_version Project Info : C8803E_Z23_ATV_YAF Compile Date : 20130615Sat1635 [BIN] Saved as : test_version_C8803E_Z23_ATV_YAF_CT8851E_flsh_spi64m.bin Done Elapsed: 00:36:01 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to saeedullah_khan For This Useful Post: |
03-23-2014, 16:37 | #20 (permalink) | |
03-23-2014, 16:43 | #21 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Nokia 210 RDA 8851 8mb(test report) Nokia 210 RDA 8851 8mb(test report) Write Flash Done Code: Load file... BIN (MCU) : test_version_C8803E_Z23_ATV_YAF_CT8851E_flsh_spi64m.bin Target BbCpu : CT8851E Target Flash : flsh_spi64m Project Name : test_version Project Info : C8803E_Z23_ATV_YAF Compile Date : 20130615Sat1635 Load Ok Operation : Flash ======= Settings Settings : BIN : NVwrite Disabled Settings : Factory Settings Enabled ======= Flash Files set for flashing : [ MCU ] : test_version_C8803E_Z23_ATV_YAF_CT8851E_flsh_spi64m.bin Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1700 FL_CNM : GigaDevice , GD25Q64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Use : 8809_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! ======= Flashing MCU Processing file : test_version_C8803E_Z23_ATV_YAF_CT8851E_flsh_spi64m.bin CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Flash Done ======= Setting Factory Defaults Calculating new values... NVMFAT Area : 0x00700000 , Len : 0x000FC000 Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:08:50 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to saeedullah_khan For This Useful Post: |
03-23-2014, 16:55 | #22 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Nokia 210 RDA 8851 8mb(test report) Format FS Code: Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1700 FL_CNM : GigaDevice , GD25Q64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Use : 8809_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x00700000 , Len : 0x000FC000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:02:58 Reconnect Power/Cable! |
The Following 8 Users Say Thank You to saeedullah_khan For This Useful Post: |
03-23-2014, 22:11 | #24 (permalink) |
Insane Poster Join Date: Dec 2013 Location: MOBIE HEART
Member: 2084844 Status: Offline Sonork: 100.1611742 Thanks Meter: 18 | Chines by2 k8802 read succes in infinity cm2 Start at : [3/24/2014 / 2:29:36 AM] Operation : Read FullFlash ======= Settings Settings : SafeMode is On [Slow] Settings : Make IFF (MCU) file Settings : Make Calibration file Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Boot Done! Read Flash now ... Read Ok, 4194304 bytes read Verify file... Target BbCpu : CT8851A Target Flash : flsh_spi32m Project Name : C01E_BH_T41_RDA8851A_ST3216_PCB40_QVGA_S_ENG_ARA_H IN_BY2_V02 Project Info : BH_C01E_T41_RDA8851A_3216_QVGA Compile Date : 20121110Sat1450 [BIN] Saved as : C01E_BH_T41_RDA8851A_ST3216_PCB40_QVGA_S_ENG_ARA_H IN_BY2_V02_BH_C01E_T41_RDA8851A_3216_QVGA_CT8851A_ flsh_spi32m.bin Make FlashFiles FATNV Check passed FSCSC Check passed CALIB Check passed [IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\C01E_BH_T41_RDA885 1A_ST3216_PCB40_QVGA_S_ENG_ARA_HIN_BY2_V02_BH_C01E _T41_RDA8851A_3216_QVGA_CT8851A_flsh_spi32m.iff [CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\C01E_BH_T41_RDA885 1A_ST3216_PCB40_QVGA_S_ENG_ARA_HIN_BY2_V02_BH_C01E _T41_RDA8851A_3216_QVGA_CT8851A_flsh_spi32m.ifc Build done Done Elapsed: 00:04:42 Finish at : [3/24/2014 / 2:34:19 AM] Reconnect Power/Cable! |
The Following 3 Users Say Thank You to .::KHAN::. For This Useful Post: |
03-24-2014, 06:31 | #25 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | LVTel L8 RDA 8851 4mb(test report) READ INFO Code: Operation : Check Device / Info ======= Settings Settings : Read AllInfo is On Settings : Full Boot disabled by default Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Checking step 1, wait ... Checking step2, wait ... Elapsed: 00:00:17 Done Reconnect Power/Cable! Code: Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read done, sorting EXTData Following items found : Item : NVRAM Required data found, extracting code UserCode : 1234 Elapsed: 00:00:47 Done Reconnect Power/Cable! Code: Operation : Factory Area Rebuild [Repair IMEI] Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Factory Sector ... Read Ok , verify Detected 2 Sim Slot(s) Current Phone IMEI : IMEI1 : 352995052677239 IMEI2 : 352995052677247 New Phone IMEI : IMEI1 : 35001000000655-6 IMEI2 : 35002000009887-5 Build Factory Sector Write Factory Sector CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Verify Factory Sector Sector Verifyed! IMEI Write Done! Elapsed: 00:00:12 Reconnect Power/Cable! Code: Chinese Miracle II [RDA module] v 0.03 Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Flash now ... Read Ok, 4194304 bytes read Verify file... Target BbCpu : CT8851A Target Flash : flsh_spi32m Project Name : BV105 Project Info : 8851a_5169_qqvga_3216_L8 Compile Date : 20130518Sat1726 [BIN] Saved as : BV105_8851a_5169_qqvga_3216_L8_CT8851A_flsh_spi32m.bin Make FlashFiles FATNV Check passed FSCSC Check passed CALIB Check passed [IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\BV105_8851a_5169_qqvga_3216_L8_CT8851A_flsh_spi32m.iff [CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\BV105_8851a_5169_qqvga_3216_L8_CT8851A_flsh_spi32m.ifc Build done Done Elapsed: 00:18:01 Reconnect Power/Cable! WRITE FLASH Code: Load file... BIN (MCU) : BV105_8851a_5169_qqvga_3216_L8_CT8851A_flsh_spi32m.bin Target BbCpu : CT8851A Target Flash : flsh_spi32m Project Name : BV105 Project Info : 8851a_5169_qqvga_3216_L8 Compile Date : 20130518Sat1726 Load Ok Operation : Flash ======= Settings Settings : BIN : NVwrite Disabled Settings : Factory Settings Enabled ======= Flash Files set for flashing : [ MCU ] : BV105_8851a_5169_qqvga_3216_L8_CT8851A_flsh_spi32m.bin Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! ======= Flashing MCU Processing file : BV105_8851a_5169_qqvga_3216_L8_CT8851A_flsh_spi32m.bin CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Flash Done ======= Setting Factory Defaults Calculating new values... NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:03:53 Reconnect Power/Cable! Code: Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:01:08 Reconnect Power/Cable! |
03-24-2014, 06:32 | #27 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Kfive vanilla rda cpu read info/code/full flash sucessfully KFIVE VANILLA COOLSEND CPU READ INFO READ PHONE CODE READ FULL FLASH |
The Following User Says Thank You to Deepesh Sharma For This Useful Post: |
03-24-2014, 06:53 | #28 (permalink) |
Product Supporter Join Date: Nov 2010 Location: Every where
Member: 1549240 Status: Offline Thanks Meter: 1,130 | Nokia Clone X2-02(Dead) Read Info Code: Chinese Miracle II [RDA module] v 0.04 Start at : [3/24/2014 / 10:38:58 AM] Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU Current CPU is under test support! Make 'FlashRead' before 'Format' or 'Flash Write' operations! CPU_ID : 880A , rev : 7002 CPU_CN : CoolSand CT , RDA8853B ==== FLASH FL_VEN : 25C2 , rev : 3700 FL_CNM : Macronix , MX25U64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Use : 880A_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Elapsed: 00:00:08 Code: Start at : [3/24/2014 / 10:40:21 AM] Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU Current CPU is under test support! Make 'FlashRead' before 'Format' or 'Flash Write' operations! CPU_ID : 880A , rev : 7002 CPU_CN : CoolSand CT , RDA8853B ==== FLASH FL_VEN : 25C2 , rev : 3700 FL_CNM : Macronix , MX25U64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Use : 880A_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x00700000 , Len : 0x000FC000 Range as Factory Defined Format User Area ... CSD WR : 81C056FC , 81C05710 CSD DR : A0000000 , A0008000 , A0010000 CSD MB : 00008000 Format Done Elapsed: 00:03:03 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to ORANGE MOB For This Useful Post: |
03-24-2014, 06:59 | #29 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Thanks for 880A Test Report! I had only one dead phone with faulty CPU and add it only as I think Please, make FullFlash read and send me backup , I will add some thing in next updates. |
