03-24-2014, 13:53 | #48 (permalink) |
Freak Poster Join Date: Feb 2006 Location: country Pakistan city mailsi
Member: 238322 Status: Offline Thanks Meter: 34 | Thanks to infinity team After 2 year i use the my box today First i activate cm2 then activate dc-unlocker too and test cm2 on a on set (110 rda 8851) format it read code change imie all function works perfect read flash take long time but it is not a problem nice update thanks to infinity team infinity is great urs brother Aslamjana |
03-24-2014, 14:20 | #50 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Infront Of My Laptop Age: 34
Member: 799558 Status: Offline Thanks Meter: 430 | Start at : [3/24/2014 / 6:46:13 PM] Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4007 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:01:07 Reconnect Power/Cable! Finish at : [3/24/2014 / 6:47:21 PM] |
03-24-2014, 14:41 | #51 (permalink) |
No Life Poster Join Date: May 2008
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | M best X2 02 reed code done Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read done, sorting EXTData Following items found : Item : NVRAM Required data found, extracting code UserCode : 8285 Elapsed: 00:00:43 Done Reconnect Power/Cable! |
03-24-2014, 15:17 | #52 (permalink) |
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | GFIVE W5 read flash with infinity box Done Reconnect Power/Cable! Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 25C2 , rev : 3700 FL_CNM : Macronix , MX25U64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Use : 8809_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Flash now ... Read Ok, 3178496 bytes read Verify file... Con't collect Project Info , saving as default Saved as : 88094006_00800000.bin Done Elapsed: 00:13:46 Reconnect Power/Cable! |
03-24-2014, 15:29 | #53 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
Also - send dump me, it help further development. | |
03-24-2014, 16:46 | #55 (permalink) |
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | GFIVE w39 write ime Card found: Chinese Miracle II [RDA module] v 0.04 Operation : Factory Area Rebuild [Repair IMEI] Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Factory Sector ... Read Ok , verify Detected 4 Sim Slot(s) Current Phone IMEI : IMEI1 : 354967468743574 IMEI2 : 354984354764135 IMEI3 : 354984134684135 IMEI4 : 354967463546843 New Phone IMEI : IMEI1 : 35498465464154-4 IMEI2 : 35497435498434-4 IMEI3 : 35489432164651-3 IMEI4 : 35498465794646-0 Build Factory Sector Write Factory Sector CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Verify Factory Sector Sector Verifyed! IMEI Write Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
03-24-2014, 17:14 | #56 (permalink) |
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | MOVIL M108 invalid ime done Operation : Factory Area Rebuild [Repair IMEI] Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Factory Sector ... Read Ok , verify Detected 2 Sim Slot(s) Current Phone IMEI : IMEI1 : 356182067676589 IMEI2 : 784775878548768 New Phone IMEI : IMEI1 : 35618205910342-0 IMEI2 : 35618205940342-4 IMEI3 : 35618205910342-0 IMEI4 : 35618205910342-0 Build Factory Sector Write Factory Sector CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Verify Factory Sector Sector Verifyed! IMEI Write Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
The Following User Says Thank You to sultan_ For This Useful Post: |
03-24-2014, 17:35 | #57 (permalink) |
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | RDA format done Card found: Chinese Miracle II [RDA module] v 0.04 Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 25C2 , rev : 3700 FL_CNM : Macronix , MX25U64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Use : 8809_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x00700000 , Len : 0x000FC000 Range as Factory Defined Format User Area ... CSD WR : 81C05C48 , 81C05C5C CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:02:59 Reconnect Power/Cable! |
03-24-2014, 17:56 | #58 (permalink) |
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | LVTel L8 read fonecode Operation : Read User Code Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4006 CPU_CN : RDA Micro CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read done, sorting EXTData Following items found : Item : NVRAM Required data found, extracting code UserCode : 7777 Elapsed: 00:00:45 Done Reconnect Power/Cable! |
03-24-2014, 18:52 | #59 (permalink) |
No Life Poster Join Date: Feb 2010
Member: 1228709 Status: Offline Thanks Meter: 269 | Testing with dead phone.. Code: Chinese Miracle II [RDA module] v 0.04 Operation : Check Device / Info ======= Settings Settings : Read AllInfo is On Settings : Full Boot disabled by default Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Checking step #1, wait ... Checking step #2, wait ... Elapsed: 00:00:07 Done Code: Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Recalculate Format Range Format User Area ... CSD WR : 00000004 , 00000018 CSD DR : 64208228 , 64208228 , 6420C228 CSD MB : 64208228 General Error , Registers Init not passed! Elapsed: 00:00:07 anyway, phone is dead. |
03-24-2014, 19:08 | #60 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,972 | Quote:
