11-08-2016, 06:54 | #604 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,931 | Quote:
05-31-2017, 11:54 | #605 (permalink) | |
Insane Poster Join Date: Sep 2012 Location: india Age: 36
Member: 1807959 Status: Offline Thanks Meter: 17 | Quote:
i need to remove pattern unlock for lava iris atom 3... what is boot key for info | |
06-10-2017, 16:46 | #607 (permalink) |
Insane Poster Join Date: Feb 2017 Location: Gazipur
Member: 2680150 Status: Offline Thanks Meter: 10 | InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Boot Files missing! Select SLDR or PAC file! Boot failed! Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.26 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 43 ] Port Opened Sync... Initial Boot Failed! Boot not done, reason : Wrong BootKeys Hint : Reset power and use ANOTHER BootKey ( VOL up or VOL down ) Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.26 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 43 ] Port Opened Sync... Initial Boot Failed! Boot not done, reason : Wrong BootKeys Hint : Reset power and use ANOTHER BootKey ( VOL up or VOL down ) Reconnect Power/Cable! |
06-21-2017, 11:05 | #608 (permalink) |
No Life Poster Join Date: Jul 2013 Location: gsm forum
Member: 1984655 Status: Offline Sonork: 119.30.39.25 Thanks Meter: 81 | Chinese Miracle-2 SPD/Spreadtrum exe not run out of date mtk exe run DongleManager [Infinity] v1.70 [6/21/2017 16:03:30] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0101A0641C6A1292 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): D25BA064 Firmware version: 0134.02 === Process started: 6/21/2017 16:03:31 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! |
10-11-2017, 19:17 | #612 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,931 | |
10-31-2017, 10:15 | #613 (permalink) | |
Junior Member Join Date: Feb 2010
Member: 1239556 Status: Offline Thanks Meter: 1 | Quote:
same problem sir.. how to fix it...?? | |
11-01-2017, 12:52 | #614 (permalink) |
Freak Poster Join Date: Jun 2011
Member: 1607677 Status: Offline Thanks Meter: 272 | Hello, What is your Support Validity Date ? How to check - http://www.infinity-box.com/doc/?r=17 If support is expired please contact to any seller and renew support. |
The Following User Says Thank You to GreenBoss For This Useful Post: |
11-01-2017, 15:48 | #615 (permalink) | |
