03-15-2006, 00:49 | #1 (permalink) |
Freak Poster Join Date: Oct 2005 Age: 36
Member: 187541 Status: Offline Thanks Meter: 0 | cl75 restart at siemens logo after flash BR |
03-15-2006, 07:54 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | pls, log file to check, can't give any advice before I see Log file. you can try to use this: http://forum.gsmhosting.com/vbb/showthread.php?t=248879 |
03-15-2006, 20:35 | #3 (permalink) |
Member: 187541 Status: Offline Thanks Meter: 0 | hi, this is the log of flash fireware, map and lang pack Current device: CL75 Loading... CL75_100D_Main.21M.bin Loaded Loading... CL75_Map_DF-M22.10.21F.bin Loaded Loading... CL75_100_LP08L2707_Cn.21P.bin Loaded COM1 selected Device: CL75 Checking data, wait... Action: Flash write "SmartWrite" enabled Write: Firmware Write: MAP/Customization Write: Language Pack Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! FLASH: 01227E22202200 FLASH: 98E59F00000000 Boot Done Set baud... Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Erasing... Erasing Done Writing... Write: Firmware Write: MAP/Customization Write: Language Pack Writing Done Finished Remove/Install battery now ! Time used: 1796 sec then i reset the phone: COM1 selected Device: CL75 Checking data, wait... Action: Reset Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! FLASH: 01227E22202200 FLASH: 98E59F00000000 Boot Done Set baud... Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Erasing... Erasing Done Writing... Writing Done Finished Remove/Install battery now ! Time used: 18 sec and then i write eprom: Current device: Siemens CL75 Loading... CL75_Repair_eeprom01.21E.bin Loaded COM1 selected Device: Siemens CL75 Checking data, wait... Action: Flash write "SmartWrite" enabled Skip: Firmware Skip: Map/Customization Skip: Language Pack Write: Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 01227E22202200 Flash: 98E59F00000000 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Erasing... Erasing Done Writing... Write: Eeprom Writing Done Finished Remove/Install battery now ! Time used: 38 sec |
02-01-2007, 12:14 | #9 (permalink) |
Freak Poster Join Date: Jun 2003 Location: LZ - Bulgaria
Member: 30940 Status: Offline Thanks Meter: 13 | same hapens to me i need to put in that fu.... phone original contents flash it with infinity - CONTENTS WAS THERE after that i try to open xxxxx.GIF - unsuported fail format flash it again - no contents in it take a puicture - all fine , there is my photo and it is opened fine but i need contents !!! download CL75 update from original BENQ-SIEMENS site - two versions COM and USB start to flash with COM , error on 80% , than on 20% , but phone can SWITCH ON normally , i didnt look for contents than flash it via USB with ORIGINAL UPDATER , all past fine but when i power on phone , only LOGO and thats it , ....... BELEIVE ME i try everything after that with INFINITY .... NO SUCCESS i need HEEELP now i see that this is POPPY , but i flash it with regular CL75 SW there is no SW for POPPY in the BENQ - SIEMENS SUPPORT what to do ???? I NEED HEEEEEELP |
02-01-2007, 12:16 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, What was phone original state ? What was the reason you flashed it first time ? try to flash different set of files. It's important to write 3 files together: main + lp + map |
02-01-2007, 17:13 | #11 (permalink) |
Member: 30940 Status: Offline Thanks Meter: 13 | ORIGINAL STATE - OK but without contents in user memory all folders empty , no images , no sounds , customer want original 1.FLASH with infinity , contents was there but when open original ***.GIF give "UNSUPORTED FAIL FORMAT" 2.FLASH , FLASH , REPAIR EEPROM , FFS FORMAT , all ... and nothing ... all folders remain empty , but HW flash IC i thing OK , coz when i take a picture with camera , *****.JPG fail was there and opening fine 3.I deside to flash with original flasher from support http://www.benq-siemens.com/cds/fron...130802,00.html first flash with serial cabel , give me error , i think battery was low 4.than i change the battery and start with USB downloader all start fine , there is message "need to reformat file system, all contents will lost" something like this , i said "OK" and all pass fine " SUCCESSFULL" but the phone power and remain at startup logo AND WITH THIS START ALL MY TROUBLES ..... |
05-30-2007, 13:27 | #15 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! have you tried what we adviced above? Flash 3 parts together (main +lp + map) according to FlashFileDescription manual fromn support area. This is important because flash files must be correspondent to each other! Make "reset". |
Cl75 stop at siems logo then restarts | jamohaki | NON Siemens Brand (ODM Phones) | 11 | 06-11-2009 13:01 |
A637 restart at att logo. after flash | rudyandremely | UST Pro II | 5 | 05-18-2009 10:01 |
D820 restart at startup logo | mitko8103 | Samsung Hardware Repair | 18 | 01-12-2009 07:53 |
cl75 siemens ded after flash | AL-NAJAT | Infinity-Box | 1 | 03-04-2008 08:43 |
Nokia 1110 & 1600 Restart At nokia Logo | Aazib jhon | Nokia Hardware & Hardware Repair | 4 | 01-01-2008 14:44 |
