10-19-2016, 08:47 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | cm2 not activated on best "you must activate this software via infinity online service" how can i do now |
05-10-2017, 21:45 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Hello, What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 Also you can insert Smart-Card into another Card-Reader. 2. Run DongleManager 3. Update Dongle firmware - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! |
05-11-2017, 17:58 | #5 (permalink) | |
Freak Poster Join Date: Apr 2015 Location: GHANA Age: 28
Member: 2373688 Status: Offline Thanks Meter: 57 | Quote:
This is What i get now and it says dongle not connected DongleManager [Infinity] v1.70 [5/11/2017 9:57:39] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 01049D5A24881292 === Process started: 5/11/2017 9:57:39 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 | |
05-14-2017, 23:06 | #9 (permalink) | |
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 Also you can insert Smart-Card into another Card-Reader. 2. Run DongleManager 3. Update Dongle firmware - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! | |
05-16-2017, 01:40 | #10 (permalink) | |
i have done that. drivers installed fine but when i tried to update i get error. Failed to upgrade applet. I do not have any different smart card to test it but i really need my dongle working | |
05-16-2017, 09:54 | #13 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
2. Do you have another PC to try ? | |
