01-05-2016, 10:32 | #1 (permalink) |
Freak Poster Join Date: Jun 2011
Member: 1603029 Status: Offline Thanks Meter: 20 | Cm2 not reading firmware and giving error. Reading Flash Conent now ... Brand : samsung ProdName : SM-N9006 ProdModel : SM-N9006 Device : SM-N9006 AndroidVer: 4.3 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 [Read Ok] : preloader_mbk72_wet_jb3.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin Fatal error, buffer empty! Phone connection lost??? Error while reading block! Something went wrong Read error Operation Failed Reading Flash Conent now ... Brand : Micromax ProdName : A106 ProdModel : Micromax A106 Device : A106 AndroidVer: 5.0 MTKxCPU : MT6582 MTKxPRJ : ALPS.L0.MP2.V1_TINNO6582.WT.L_P22 [Read Ok] : preloader_s4700.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 #457 : Data CRC Error : AC6C , A665 Error while reading block! Something went wrong Read error Operation Failed Elapsed: 00:01:09 Reconnect Power/Cable! Reading Flash Conent now ... Brand : Lenovo ProdName : A369i ProdModel : Lenovo A369i Device : A369i AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 [Read Ok] : preloader_lcsh72_we_jb3.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin Fatal error, buffer empty! Phone connection lost??? Error while reading block! Something went wrong Read error Operation Failed Reading Flash Conent now ... Brand : samsung ProdName : Galaxy-Grand2 ProdModel : Galaxy-Grand2 Device : Galaxy-Grand2 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.JB5.MP.V1.21 [Read Ok] : preloader_mbk82_wet_jb5.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin #3753 : Data CRC Error : 8C19 , 9045 Error while reading block! Something went wrong Read error Operation Failed Elapsed: 00:02:05 Reconnect Power/Cable! |
01-05-2016, 10:50 | #2 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Fatal error, buffer empty! Phone connection lost??? check cable check battery use short cable and also use direct to pc or laptop without hub |
01-05-2016, 11:02 | #3 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Wait for phone... Phone found! [ 191 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040502A29D6D913B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A29D6D913B [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... [Read Ok] : preloader_y7262.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Error] : Bad EXT data Looks like unusable file , break! Read error Operation Failed Elapsed: 00:04:37 Reconnect Power/Cable! |
01-05-2016, 11:07 | #4 (permalink) |
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Seems as UserData is encrypted. If you not rely on it - can do "Repair ExtData", then power on phone, while it powering - press "Read FW" and connect phone. |
01-05-2016, 12:09 | #6 (permalink) | |
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
http://forum.gsmhosting.com/vbb/11525091-post2.html | |
02-07-2017, 11:36 | #7 (permalink) | |
Junior Member Join Date: Jul 2006 Location: Bangladesh,Chittagong
Member: 316771 Status: Offline Thanks Meter: 10 | Quote:
The Following 3 Users Say Thank You to Tajel For This Useful Post: |
11-01-2017, 08:55 | #8 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Balochistan
Member: 2682425 Status: Offline Thanks Meter: 66 | Read MT6572 Firmware Success with CM2 My Problem Solved by this method. I reinstalled software in other Drive except C. and that work for me. sorry for the log i accidentally close the program without saving log |
12-09-2017, 13:59 | #9 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2692475 Status: Offline Thanks Meter: 4 | Card found : S/N : 7D12845A , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333145626D0D42650516E0 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420D6D62E0168465 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x0544B048BEAF75DBDF2235AA795F9339 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:39 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333145626D0D42650516E0 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420D6D62E0168465 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x0544B048BEAF75DBDF2235AA795F9339 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : TECNO ProdName : H3712 ProdModel : TECNO WX4 Pro Device : TECNO-WX4-Pro AndroidVer: 7.0 MTKxCPU : MT6737M MTKxPRJ : WX4Pro-H3712A-N-170920V82 #0 : Data CRC Error : F659 , F6D9 Error while reading block! Something went wrong Read error Operation Failed Elapsed: 00:00:19 Reconnect Power/Cable! not reading rom from a brand new techno wx4pro :-( common problem of cm2 |
02-13-2018, 17:33 | #13 (permalink) |
Freak Poster Join Date: Feb 2014 Location: MEA Age: 30
Member: 2119579 Status: Offline Thanks Meter: 44 | Windows 10 Compatibility Issue Issue is that there is no compatibility between CM2 and Windows 10 I face the same issue I haven't found any solution yet! |
03-12-2018, 08:46 | #14 (permalink) |
Freak Poster Join Date: Mar 2014 Location: PAKISTAN
Member: 2145475 Status: Offline Thanks Meter: 100 | Chinese Miracle II [MTK module] v 1.58 Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040503A2DDE7A1F7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A2DDE7A1F7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xA940B949830B0DF2CEB946A3CB12FBA6 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : WIKO ProdName : wiko ProdModel : SUNSET Device : wiko AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP6.V1 [Read Ok] : preloader_wiko.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin #3227 : Data CRC Error : D947 , CB5F Error while reading block! Something went wrong Read error Operation Failed Elapsed: 00:01:36 Reconnect Power/Cable! |
