01-31-2016, 06:11 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | There is no any "new" cpu forma t of 6531. Exists few flash types, which not supported. Since 2 year no any user send us such phone for adding. I not see reason collect dozen of spd6531 phones for find this one. |
01-31-2016, 07:04 | #3 (permalink) |
Freak Poster Join Date: Mar 2014 Location: GSM WORLD
Member: 2140248 Status: Offline Thanks Meter: 166 | Dear 6531 CPU already supported by CM2 here is VGO TEL i250 Read Flash,Format Logs Read Flash Code: Operation : Read FullFlash [ v1.13 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 ¿A Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Read Flash Content Read Ok , collect info Set FileInfo : Model Vendor : VGO TEL Model Name : i250 ExtInfo Data : English Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD25LQ32_English__VGO TEL-i250_2.bin Done! Elapsed: 00:00:51 Code: Operation : Format File System [ v1.13 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 ‘*Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:11 |
The Following User Says Thank You to kbgsm2014 For This Useful Post: |
01-31-2016, 08:45 | #4 (permalink) | |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Quote:
Code: 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 24 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : SEND_ERROR_RSP(0x97) func:_FDL_HWInit, line:458 3è~~ Boot Ok New Flash CPU 6531 Not Support | |
