Old 10-12-2017, 20:44   #1 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,450
Exclamation CM2LGE Handset Not Detect
Hello Team
I Try To Connect 1 Handset In LG Module But It Not Detect I Try Identify But Nothing Happen Seems HID Not Added In Database Kindly Update Database...
USB\VID_1004&PID_61F1&REV_0100&MI_02
Above Mention HID For Handset
Model LG E445 MTK MT6575
While MTK Module Detect Handset But I Need To Write Factory Firmware So Kindly Add HID In LG Module or Fix Issue...
Read Info
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 113 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
BB_CPU_NME : [MediaTek] MT6575|MT6577_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201
Processing BROM stage
i2c Init : 00000000
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x82
WD Disable stat : 0x0000
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.3.2 on BBID : 0x84
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A483447316404860138FA1CD9BB
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 0xBE0EB891EFF94EFDB2CB9709488F04EF
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
SECURITY :
BTMAC Addr : 0110006B605C
WiFi MAC : 605CA607F067
Done!
Elapsed: 00:00:11
Reconnect Power/Cable!
Old 10-13-2017, 06:52   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,353
Hello. It old LG. And it not support laf. You need use MTK module for it.
Old 10-14-2017, 09:47   #3 (permalink)
Member: 1834832
Thanks Meter: 1,450
Brother I Have Factory File Only For Write (.KDZ) As I Know MTK Not Support KDZ If Possible Add Convert Option For Convert KDZ To Scatter Or KDZ Flashing In Upcoming Update.
Page generated in 0.11158 seconds with 8 queries
