01-15-2020, 06:39 | #8 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: india
Member: 1246696 Status: Offline Sonork: 100.1681950 Thanks Meter: 650 | cm2mt2 Quote:
Smart-Card update process may takes up to 4-5 minutes to complete. During update process software may seem hanging but please DO NOT close or terminate forcely application. It may cause harm to your Smart-Card. Just let the process to be finished. - Connect Infinity Box/Dongle (Smart-Card) to PC - Disconnect all other Boxes/Dongles (Smart-Card) from PC - Update Smart-Card Reader drivers to latest version - Disable Antivirus and Firewall - DO NOT interrupt update process even if you think that software is freez ! === DongleManager [Infinity] v1.72 [2020-01-13 20:02:36] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0001A5B9FF021982 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 1418A5B9 Firmware version: 0138.02 === Process started: 2020-01-13 20:02:40 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Last APDU: 47 sec Applet upgrade ok Checking Dongle Identification... Identification Ok. Finalizing... Finalizing ok Process completed === Process finished: 2020-01-13 20:03:52 === === DongleManager [Infinity] v1.72 [2020-01-13 20:03:52] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0001A5B9FF021982 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 1418A5B9 Firmware version: 0139.02 => Activations: - 00: Infinity-Box/Dongle v.0139 - 07: #7 | |
01-15-2020, 14:16 | #9 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | @umar342 Does your pc has fault.bin inside CM2MT2 installed folder? Does your pc has any kind of usb sharing software installed like Flexihub/Eltima? If so uninstall and try to open CM2MT2 module again. Br. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
01-15-2020, 19:36 | #10 (permalink) | |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Quote:
If Its Blink N Close There Must Be Fault.bin In Your Installation Directory Simply Means U Have Installed Something Which Conflict With Infinity ..Simply Uninstall All USB Sharing Software From PC N Delete Fault.bin Try To Run If Again Same Happen Fault.bin Created There Upload That File Somewhere N Attach Link In Post....Your Dongle Managers Logs Seems All OK.. Installation Directory"C:\InfinityBox" Default Then Go To Module Folder Which Is Not Working U Will Find Fault.bin There | |
The Following 2 Users Say Thank You to hitech care For This Useful Post: |
