Old 02-23-2016, 08:17   #1 (permalink)
Member: 411636
Thanks Meter: 10
xiaomi mi HM Note 1w error
Hello
i received this set on hang on logo condition, and try to flash but now set is dead, trying in CM2 but error
here is log
Card found : S/N : 02464F3F , v0130
Chinese Miracle II [MTK module] v 1.41
Scatter Load Ok , BaseBand : MT6592 , Project : MTDTtest , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.41 ]
======= Flash
Wait for phone...
Phone found! [ 16 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BB_CPU_NME : [MediaTek] MT6592_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x8A
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483847326404050174C70D6177
Initialize Memory ...
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x40000000
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d2G8
[eMMC] : FLASH_CID : 90014A483847326404050174C70D6177
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 4F65A4C0C033B1C5D55A92A5C2E22A70
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6592 , Project : MTDTtest , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
Preloader Check failed, looks like damaged!
Operation Failed
Elapsed: 00:00:09
Reconnect Power/Cable!
plz. any help.
Thanks
The Following User Says Thank You to Taturi For This Useful Post:
Old 02-23-2016, 08:35   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Logs shows phone already dead.
Make sure firmware is good which you are trying to write, by log it seems preloader damaged in firmware which you are trying to write. Try downloading new good firmware.
Br.
Infinity Box Support Team.
Old 02-23-2016, 17:36   #3 (permalink)
Member: 716073
Thanks Meter: 17
HM NOTE 1W TESTED LONG TIME AGO
Start at : [12/29/2015 / 10:25:14 PM]
Operation : Read Flash [ v1.40 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6592
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6592_S00
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v5.1540.01.01
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 90014A48384732640405018ACDE46101
DA Stat : v4.2 on BBID : 0x8A
DRAM not initialized , configure DRAM Settings
DRAM EmiReq Ok , 0x00BC
DRAM Init Ok , 0x40000000
DA Sent. Configure setting now ...
DA started successuflly
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_CID : 90014A48384732640405018ACDE46101
[eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
USBDL : Init HSUSB Ok!
Brand : Xiaomi
ProdName : lcsh92_wet_jb9
ProdModel : HM NOTE 1W
Device : lcsh92_wet_jb9
AndroidVer: 4.4.2
MTKxCPU : MT6592
MTKxPRJ : ALPS.KK1.MP1.V2.46
[Read Ok] : preloader_lcsh92_wet_jb9.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6592 / V1.1.2 / lcsh92_wet_jb9 / EMMC
FW Size : 838 MiB
Scatter saved to : G:\InfinityBox\CM2MTK\Flash\MT6592__Xiaomi__HM_NOT E_1W__lcsh92_wet_jb9__4.4.2__ALPS.KK1.MP1.V2.46\
All done!
Done!
Elapsed: 00:04:48
Finish at : [12/29/2015 / 10:30:02 PM]
The Following User Says Thank You to mawan161080 For This Useful Post:
Old 10-02-2017, 15:41   #4 (permalink)
Member: 64823
Thanks Meter: 439
Can you share the rom file?
Page generated in 0.15793 seconds with 8 queries
