08-13-2015, 10:35 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | CM2MTK always says BAD FILE SELECTED!! Operation : Read Flash [ v1.25 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 147 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00AD00BC00900055005400AD00BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x007B , [SAMSUNG] KA100O015B_BJTT [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info MTKxCPU : MT6572 MTKxPRJ : benrui72_wet_lca File conversion error, file already exists! Saved as default! Done! Elapsed: 00:03:49 Reconnect Power/Cable! Load File Bad file detected! |
08-13-2015, 12:18 | #3 (permalink) | |
No Life Poster Join Date: Apr 2015 Location: Hatfield Harare Zimbabwe Age: 42
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Quote:
im also facing the problems on mtk6571 chip mostly | |
08-13-2015, 12:39 | #5 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | this error come only in NAND chip not in emmc nand_id : 00ad00bc00900055005400ad00bc0000 emmc_id : 00000000000000000000000000000000 @all at this time NAND chip write not support so this error show don't worry its support near time |
The Following User Says Thank You to sneha For This Useful Post: |
08-13-2015, 12:40 | #6 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Nand not supported for Firmware/dump writing. It will be supported in coming updates, team is working on it. Br. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
08-31-2015, 08:51 | #7 (permalink) |
Major Poster Join Date: Jul 2006 Location: kenya
Member: 304037 Status: Offline Thanks Meter: 9 | what about NOR chip? i tried rm-969 flash file bin format but also said bad file. phone can read info with cm2mtk but cannot detect in main best setup. so confused. |
08-31-2015, 10:10 | #9 (permalink) |
Member: 1507693 Status: Offline Thanks Meter: 131 | I believe in your team, very hard working, but this update is taking too long, we have a lot of mtk nand based phones for flashing but not supported |
