10-08-2010, 06:49 | #1 (permalink) |
Major Poster Join Date: Dec 2006
Member: 410873 Status: Offline Thanks Meter: 3 | combo pinfinder |
10-08-2010, 22:07 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! which search method you use? try to make pinout search in Fast and Slow method and compare results (if they match or not). with which method you can get connection with China Miracle software? |
10-09-2010, 07:51 | #3 (permalink) |
Member: 410873 Status: Offline Thanks Meter: 3 | combo pinfinder T u for u r reply,when i conn set with cable and open the pinfinder 1.23and select cable no,also do findout pin both {slow,fast} its detect pin and set is on,then i go to chinesmircale run 3.24 select formet option its asked power on mobile,i do everthing there is a no response,thats why i asked,at the time when i detecet pinout with spiderman and conn infinety combo pinfinder box ,run chinesemircale , formet its fine working,so i confused,so pl asap to solve the my problem,this is my request,u r old addditional pinfinder box with infinity its very good,but new combo i am not satisfied,t u |
10-09-2010, 18:37 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if pinfinder detects pinout in both modes, but still can not be detected by China Miracle- i can suggest only one things: you have not selected correct COM port in China Miracle Settngs. |
10-11-2010, 06:46 | #5 (permalink) |
Member: 410873 Status: Offline Thanks Meter: 3 | combo pinfinder T u for reply, what i tell ,i conn every method but no result,so u r replt is very funny,in chinese mircale 3.24 version in setting tab select com port its show ,com1,printer port,se tool com port,combo pinfinder com port,i select combo pinfinder com port but no result that why i asked,so pl help asap ,t u |
Combo flash for 3650 | Mgsm | WD2 & APE (Symbian Phones) | 2 | 01-14-2004 09:53 |
Combo flash for 3650 | Mgsm | Nokia Multimedia | 0 | 01-13-2004 20:10 |
3650 combo flashing problem | e64y | UFS2 + UFS3-Tornadoflasher | 14 | 01-02-2004 18:07 |
Sharp GX-10i & Pansonic GD87 A39/A51 Combo Clip!!! | saejor | Main Sales Section | 0 | 07-20-2003 19:55 |
I need from hex and scheme DCT3/DCT4 combo clip? Help me please. | pc.net | Nokia Digital Core Technology 4 ( DCT-4 ) | 10 | 04-16-2003 20:37 |
