Would like to tell me, why Chinese miracle got to many errors and cpf did not, i use p908/JB518
this the log
PHP Code:
module v2.76
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read NOR flash
Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:F441:A750
status: FF
high speed boot Off
boot packet size: 0002
Release Power button now !
Boot Done
Initialize ...
flash: 98004900000002:29EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
921600
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.85FD9B34.[M448_26_26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16_MP_V7.BIN_0F8F8B4C].rpl
identification#1 detection finished
device-id: 85FD9B34
identification#1 protocol ver: 04
ver. sw 1: M448_26_26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16_MP_V7.BIN
ver. sw 2: MAUI.05C.W06.16.MP.V7, B37470F0
ffs offset/size: 00F00000/00100000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00F00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
Detected ffs/eeprom address is non-standard: 00E00000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
detecting languages...
language parameters detected
detected languages: En Cn Cn
Check firmware content Done
Backup required data ...
reading: flash[M448_26_26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16_MP_V7.BIN]...
warning: wrong data size at 0x00262C00, retry...
read error recovered
warning: wrong data size at 0x00BB0000, retry...
file saved: F:\zzz jumper\Firmware\INFINITY\BACK UP INFINITY\MT6226\p908\flash[M448_26_26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16_MP_V7.BIN]_20090219-005859.B0M.bin
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\system_log_85FD9B34_M448_26_26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16_MP_V7.BIN_0F8F8B4C_20090219-005934.B0X.bin
Finished, time used: 682 sec
Remove/Install battery now !
smart-card disconnected
