Cordless Phone FC8050- Error unlocking I tried unlocking:
1.unlock metod: read code - result-error
2.unlock metod: standart-result-done, but phone is locked
3.unlock metod: standart fast- result-done, but phone is locked
4.unlock metod: smart fast-result-error Code:
==== [16/2/2012 г. 12:39:22] ====
COM5 [VCP0] selected
module v4.16
Action: read unlock codes
unlock method: read codes
Model: _Autodetect MT6205-6239 NOR
Checking data, wait...
19200 autodetect
Initializing [6223:8A08]...
CPU: MT6223
high speed boot On
chip: 0011:55E8:000C
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6223,E08
Date: 2000.00.00
Version: 1.0
Version: 08GE0_H_07_11
Version: ATEL23_08A_HW
detecting structure #2...
1 2 3 5 7 8 9 11 13 done
80 byte(s) read
imei: 35876002429204
connection Ok
detecting structure #1...
0 1 2 3 4 7 8 9 12 13 14 15 17 20 21 22 23 24 27 28 29warning: wrong packet cs
32 33 34 35warning: wrong packet cs
37error: detection failed (26 tries), read flash and send to support
error: can't read required data
error: operation failed !
Finished, time used: 15 sec
Remove/Install battery now !
==== [16/2/2012 г. 12:39:58] ====
module v4.16
Device: _Autodetect MT6205-6239 NOR
Action: "sp-unlock"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
boot packet size: 0400
Boot Done
====> Initialize ...
flash: 7F227E220A2201:2BEA0000000000
flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
detecting chip #08 in region #00...
detecting chip #09 in region #00...
detecting chip #0A in region #00...
detecting chip #0B in region #00...
detecting chip #0C in region #00...
detecting chip #0D in region #00...
detecting chip #0E in region #00...
detecting chip #0F in region #00...
number of flash chip/regions detected: 10/01
Initialize Done
====> Set baud ...
230400
Set baud Done
====> Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00400000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (04)
TCL-ID is absent
rom info detection finished
rom info ver: 04
sw version: ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0_H_07_11.BIN
project-id: 08GE0_H_07_11, 00000000
code offset: 00000000
ffs offset/size [01]: 00380000/00080000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00380000
standard ffs/eeprom offset confirmed: 00380000
detecting ffs/eeprom size...
ffs/eeprom size: 00080000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00380000-003FFFFF
firmware area: 00000000-0037FFFF
detecting startup code area #2...
startup code area #2 is absent
detecting ffs/eeprom structure pass 1...
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect ext location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok: element #1
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0_H_07_11__ffs...
file saved: D:\Program Files\InfinityBox\MModule\Backup\FC8050\ATEL23_08A_BULGRIAN_PCB01_GSM_MT6223_S00.08GE0_H_07_11__ffs_20120216-124208.B0E.bin
Backup required data Done
====> Patch required data ...
detection procedure, wait...
detection procedure completed
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: ffs
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 2 min 21 sec
==== [16/2/2012 г. 12:47:51] ====
module v4.16
Action: "sp-unlock"
unlock method: standard fast
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
230400
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
lock area found
====> Write ...
Write: lock-area-1
Write Done
Finalization Done
Finished, time used: 1 min 36 sec
==== [16/2/2012 г. 12:51:29] ====
module v4.16
Action: "sp-unlock"
unlock method: smart fast
19200 autodetect
CPU: MT6223
high speed boot On
status: FF
Date: 2000.00.00
Version: 1.0
80 byte(s) read
connection Ok
0 1 2 3 4 7 8 9 12 13 14 15 17 20 21 22 23 24 27 28 29 32 33 34 35warning: wrong packet cs
Finished, time used: 17 sec
Remove/Install battery now ! |
