06-22-2010, 15:08 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 37
Member: 199814 Status: Offline Thanks Meter: 1,960 | CPU: MT346C not supported yet! module v3.15 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [346C:0001]... CPU: MT346C high speed boot On error: hardware is not supported: [0000346C:00000001] Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 3 sec Remove/Install battery now ! |
The Following User Says Thank You to asadnow2k For This Useful Post: |
06-30-2010, 10:07 | #3 (permalink) |
No Life Poster Join Date: Aug 2004 Location: india Age: 51
Member: 78028 Status: Offline Thanks Meter: 90 | COM31 [VCP0] selected module v3.15 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [346C:0001]... CPU: MT346C high speed boot On error: hardware is not supported: [0000346C:00000001] Can not initialize test mode, possible reasons: 1. communication fault, repeat required operation 2. ffs/eeprom is seriously damaged, use repair ffs/eeprom files or use another unlock/format method error: operation failed ! Finished, time used: 14 sec Remove/Install battery now ! CPU MEDIATEK MT6253N |
The Following User Says Thank You to devika For This Useful Post: |
06-30-2010, 17:17 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,993 | Hello, Please, read this phone flash backup with "NAND" model selection and send full flash backup to [email protected] |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
07-07-2010, 15:17 | #5 (permalink) | |
Junior Member Join Date: Apr 2010 Location: jaipur Age: 33
Member: 1292046 Status: Offline Thanks Meter: 1 | Quote:
module v3.13 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [346C:0001]... CPU: MT346C high speed boot On error: hardware is not supported: [0000346C:00000001] Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 14 sec Remove/Install battery now ! | |
The Following User Says Thank You to mckumawat1985 For This Useful Post: |
07-07-2010, 15:18 | #6 (permalink) |
Member: 1292046 Status: Offline Thanks Meter: 1 | COM4 [VCP0] selected module v3.13 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [346C:0001]... CPU: MT346C high speed boot On error: hardware is not supported: [0000346C:00000001] Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 14 sec Remove/Install battery now ! |
07-13-2010, 14:46 | #8 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: P@kIsTaN
Member: 327384 Status: Offline Sonork: 100.1605419 Thanks Meter: 312 | Quote:
The Following User Says Thank You to rameez_gsm For This Useful Post: |
08-01-2010, 12:34 | #12 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 950629 Status: Offline Thanks Meter: 105 | @ YellowBoss CPU NAME: MEDIATEK ARM MT 6253N But infinity detect this CPU as MT346C Can you add this CPU support for infinity box? @ asadnow2k NO! spider man box or Infinity box not work with this CPU yet. see.. Imageshack - 39554907.jpg |
09-01-2010, 07:31 | #15 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: .:INDIAN:.
Member: 75838 Status: Offline Thanks Meter: 67 | Cpu mt346c i have also same problem NEW CUP MT346C not comunicate with software plz help infinity team thanks Quote:
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
