09-05-2010, 13:24 | #17 (permalink) |
Freak Poster Join Date: May 2007
Member: 507911 Status: Offline Thanks Meter: 22 | i faced that problem to with this type of cpu , please update as soon as possible ......... COM3 [VCP4] selected module v3.22 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [346C:0001]... CPU: MT346C high speed boot On error: hardware is not supported: [0000346C:00000001] Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 42 sec Remove/Install battery now ! |
09-10-2010, 14:44 | #20 (permalink) |
Freak Poster Join Date: Jul 2006 Location: ONLY WITH YOU Age: 39
Member: 314847 Status: Offline Thanks Meter: 102 | COM18 [VCP0] selected module v3.20 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [346C:0001]... CPU: MT346C high speed boot On error: hardware is not supported: [0000346C:00000001] Can not initialize test mode, possible reasons: 1. communication fault, repeat required operation 2. ffs/eeprom is seriously damaged, use repair ffs/eeprom files or use another unlock/format method error: operation failed ! Finished, time used: 7 sec Remove/Install battery now ! |
09-10-2010, 14:57 | #21 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: player /-GSM-\ Field
Member: 161115 Status: Offline Sonork: Here you can find it... Thanks Meter: 3,039 | Quote:
09-10-2010, 15:01 | #22 (permalink) | |
Banned Join Date: Feb 2008 Age: 34
Member: 696872 Status: Offline Thanks Meter: 18 | wait bro Quote:
wait bro for update infinity is try to solve this update | |
The Following User Says Thank You to ashish51047004 For This Useful Post: |
09-14-2010, 12:46 | #24 (permalink) |
No Life Poster Join Date: Apr 2008 Location: K.G.M Age: 50
Member: 751908 Status: Offline Thanks Meter: 186 | COM3 [VCP0] selected module v3.21 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[0093]: 0089:890300000000 [INTEL] PF38F30xxM0x1xx chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00000108 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done interesting cpu type found: 6253:8A02:8A00 ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: B052-2A_L135_V101 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: HEXING53_09A_GEMINI_PCB01_GPRS_MT6253_S00.B052-2A_L135_V101.BIN project-id: B052-2A_L135_V101, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: 2nd [standard] type TCL-ID is absent ===> done ==================== New firmware detected (v.3.21, database date: 31.08.2010): HEXING53_09A_GEMINI_PCB01_GPRS_MT6253_S00.B052-2A_L135_V101.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== error: can not format: HW_STORAGE_NANDis not present Disconnect... done Finished, time used: 1 min 16 sec Remove/Install battery now ! |
09-22-2010, 08:28 | #29 (permalink) |
No Life Poster Join Date: Jan 2007 Location: PANGANDARAN BEACH Age: 44
Member: 427685 Status: Offline Thanks Meter: 103 | soft problem software version: 1.20 cable type: 1x5 (L5A) platform: MT: MT62xx (autodetect) searching adapter at COM3... adapter found, version: 2000 pins: 5, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT346C result: Rx:4 Tx:2 time required: 7 sec Trying to Power-On... Power On ! software version: 1.20 cable type: 1x5 (L5A) platform: MT: MT6205, MT6217-MT6235 searching adapter at COM3... adapter found, version: 2000 pins: 5, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT346C result: Rx:4 Tx:2 time required: 7 sec Trying to Power-On... Power On ! try with free add on from lg box with pinfinder Selected model is:Generic MT62XX NOR:AUTO Press Connect to detect memory config... Starting flasher module.... [BOOT_MODE] Boot filename: C:\Program Files\Z3X\MTK\JRD_AllInOne_DA.bin Reconnect battery and press power button now! Getting MCUID... Booting... You can release power key now! Project Name: MT6253_S00 [!] Failed to detect RAM (Possible HW failure) NOR Detected : N/A NAND Detected : N/A Advanced detection information: BBCHIP: "MT6253_S00", EXT_26M CODE(0x6253), VER(0x8A02), SW(0x8A00) NOR_ID: "NOR_UNKNOWN" NOR_ID: 0x00EC, 0x2404, 0x0000, 0x0000 NAND_ID: "NAND_UNKNOWN" NAND_ID: 0x0000, 0x0000, 0x0000, 0x0000 Detection Done! Error: S_DA_NOR_UNSUPPORTED_DEV_ID(3009) BOOT Analisys failed... Selected model is:Generic MT62XX NOR:AUTO Press Connect to detect memory config... Starting flasher module.... [BOOT_MODE] Boot filename: C:\Program Files\Z3X\MTK\MTK_AllInOne_DA_new.bin Reconnect battery and press power button now! Getting MCUID... Booting... You can release power key now! Project Name: MT6253_S00 [!] Failed to detect RAM (Possible HW failure) NOR Detected : (128Mb+0Kb) Unnamed Flash NAND Detected : N/A Advanced detection information: BBCHIP: "MT6253_S00", EXT_26M CODE(0x6253), VER(0x8A02), SW(0x8A00) NOR_ID: "Unnamed Flash" NOR_ID: 0x00EC, 0x2404, 0x0000, 0x0000 NAND_ID: "NAND_UNKNOWN" NAND_ID: 0x0000, 0x0000, 0x0000, 0x0000 Detection Done! Reading NOR : "C:\Program Files\Z3X\MTK\MTKBOOT.TMP", 0x00000000:0x00080000 Operation Done! Setting NOR buffer size :1000000 PostProcessing Boot File ROMINFO V7 Structure found! Ver.:RATECH53_09A_PCB01_GPRS_MT6253_S00.X19_HT_B_S S_MLA_06S0804.BIN_FLNK5N2866ATD_BQ12 Platform:X19_HT_B_SS_MLA_06S0804 Filesystem:00F00000:00100000 This device have no SEC block (Safe for READ/WRITE) Done! Starting flasher module.... [READ_MODE] Reconnect battery and press power button now! Getting MCUID... Booting... You can release power key now! Project Name: MT6253_S00 [!] Failed to detect RAM (Possible HW failure) NOR Detected : (128Mb+0Kb) Unnamed Flash NAND Detected : N/A Advanced detection information: BBCHIP: "MT6253_S00", EXT_26M CODE(0x6253), VER(0x8A02), SW(0x8A00) NOR_ID: "Unnamed Flash" NOR_ID: 0x00EC, 0x2404, 0x0000, 0x0000 NAND_ID: "NAND_UNKNOWN" NAND_ID: 0x0000, 0x0000, 0x0000, 0x0000 Detection Done! Reading NOR : "C:\Documents and Settings\RUBY\My Documents\RATECH53_09A_PCB01_GPRS_MT6253_S00.X19_H T_B_SS_MLA_06S0804.BIN_FLNK5N2866ATD_BQ12", 0x00000000:0x01000000 Operation Done! Selected model is:Generic MT62XX NOR:AUTO Press Connect to detect memory config... Starting flasher module.... [FORMAT_MODE] Reconnect battery and press power button now! Reset NVRAM to factory default setting ... Connected in META Mode. BaseBand Chip version : MT6253, E02 DSP Firmware ver. : 2000.00.00 Software version : X19_HT_B_SS_MLA_06S0804 Hardware version : RATECH53_09A_HW Melody version : Melody V0.0 NVM Reset OK. Operation Done! Selected model is:Generic MT62XX NOR:AUTO Press Connect to detect memory config... Starting flasher module.... [BOOT_MODE] Boot filename: C:\Program Files\Z3X\MTK\MTK_AllInOne_DA_new.bin Reconnect battery and press power button now! Getting MCUID... Booting... You can release power key now! Project Name: MT6253_S00 [!] Failed to detect RAM (Possible HW failure) NOR Detected : (128Mb+0Kb) Unnamed Flash NAND Detected : N/A Advanced detection information: BBCHIP: "MT6253_S00", EXT_26M CODE(0x6253), VER(0x8A02), SW(0x8A00) NOR_ID: "Unnamed Flash" NOR_ID: 0x00EC, 0x2404, 0x0000, 0x0000 NAND_ID: "NAND_UNKNOWN" NAND_ID: 0x0000, 0x0000, 0x0000, 0x0000 Detection Done! Reading NOR : "C:\Program Files\Z3X\MTK\MTKBOOT.TMP", 0x00000000:0x00080000 Operation Done! Setting NOR buffer size :1000000 PostProcessing Boot File ROMINFO V7 Structure found! Ver.:RATECH53_09A_PCB01_GPRS_MT6253_S00.X19_HT_B_S S_MLA_06S0804.BIN_FLNK5N2866ATD_BQ12 Platform:X19_HT_B_SS_MLA_06S0804 Filesystem:00F00000:00100000 This device have no SEC block (Safe for READ/WRITE) Done! thank |
09-22-2010, 08:44 | #30 (permalink) |
Member: 427685 Status: Offline Thanks Meter: 103 | software version: 1.20 cable type: 1x5 (L5A) platform: MT: MT62xx (autodetect) searching adapter at COM3... adapter found, version: 2000 pins: 5, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT346C result: Rx:4 Tx:2 time required: 7 sec COM3 selected module v3.22 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C1]: 00EC:240400000000 [SAMSUNG] K5N2833ATB chip size: 16Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done interesting cpu type found: 6253:8A02:8A00 ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: X19_HT_B_SS_MLA_06S0804 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: RATECH53_09A_PCB01_GPRS_MT6253_S00.X19_HT_B_SS_MLA _06S0804.BIN_FLNK5N2866ATD_BQ12 project-id: X19_HT_B_SS_MLA_06S0804, 00000000 code offset: 00000000 ffs offset/size [02]: 00F00000/00100000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.22, database date: 02.09.2010): RATECH53_09A_PCB01_GPRS_MT6253_S00.X19_HT_B_SS_MLA _06S0804.BIN_FLNK5N2866ATD_BQ12 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 15Mb number of areas/bytes to read: 1:00F00000 reading (HW_STORAGE_NOR)... file saved: C:\Documents and Settings\RUBY\My Documents\RATECH53_09A_PCB01_GPRS_MT6253_S00.X19_H T_B_SS_MLA_06S0804.BIN_FLNK5N2866ATD_BQ12__firmwar e_20100922-144212.B0M.bin Disconnect... done Finished, time used: 8 min 0 sec Remove/Install battery now ! COM3 selected module v3.22 Action: reset settings ("format ffs") Model: Autodetect 6228-6239 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [346C:0001]... CPU: MT346C high speed boot On error: hardware is not supported: [0000346C:00000001] Can not initialize test mode, possible reasons: 1. communication fault, repeat required operation 2. ffs/eeprom is seriously damaged, use repair ffs/eeprom files or use another unlock/format method error: operation failed ! Finished, time used: 4 sec Remove/Install battery now !can not format |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
