Old 09-19-2011, 06:43   #1 (permalink)
Member: 1566655
Question CSL M50 so dead
please help me ...
Brands CSL M50 mobile phone type. The first mobile conditions, when the direct entry menu screen white, then I do format user area using V4.01 Mmodule infinity with tab service/format/complete mode, and my mistakes without backup full flash, now mobile phones are switched off are logs infinity Mmodule V4.01:
COM3 [VCP0] selected
module v4.01
Device: _Autodetect MT6205-6239 NOR
Checking data, wait...
Action: read/check information
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:1FA8:C9A8
status: FF
high speed boot Off
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98004900000002:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
otp offset: 00FF0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (04), 1 record(s)
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.DA62256A .[FLYWHEEL26_06B_PCB01_GPRS_MT6226_S01.GA01_JHR_HX28 _T_ML_V05.BIN_249582E5].rpl
New firmware found (v.4.01, database date: 19.08.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
device-id: DA62256A
rom info ver: 04
sw version: FLYWHEEL26_06B_PCB01_GPRS_MT6226_S01.GA01_JHR_HX28 _T_ML_V05.BIN
project-id: GA01.JHR.HX28.T.ML.V05, E5829524
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
detecting ffs/eeprom structure pass 1...
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect ext location pass #1...
ffs/eeprom: detect ext2 location pass #1...
warning: ffs/eeprom location can't be detected
error: ffs/eeprom detection failed: element #1
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
detecting firmware version...
firmware version: FLYWHEEL26_06B_PCB01_GPRS_MT6226_S01.GA01_JHR_HX28 _T_ML_V05.BIN
detecting firmware build...
done
detecting product-id...
done
detecting languages...
error: can't detect language parameter #1
warning: can not detect language names
if software freez: make "Find language names (slow process)" unchecked and repeat operation.
file saved: c:\InfinityBox\MModule\backup_security\FLYWHEEL26_ 06B_PCB01_GPRS_MT6226_S01.GA01_JHR_HX28_T_ML_V05__ system_log_DA62256A_249582E5_20110919-121611.B0X.bin
Finished, time used: 5 min 23 sec
Remove/Install battery now !
I think mobile phones should be in flash back, but I can not find the firmware of this phone, are you all anyone knows or has this firmware, maybe anyone have a solution for this problem my mobile phone
Old 09-19-2011, 07:17   #2 (permalink)
Member: 1566655
is there someone who can help me
Old 09-20-2011, 19:40   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
if you did not disable automatic eeprom backup- it was made during format operation.
find it, load as eeprom and write back to phone
Repaired dead phone without backup Prodigal Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-29-2011 11:26
help! Dead 5110 v5.30 aklishin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 04-04-2001 11:56
why so much battle with black listed phones? Zianna Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-06-2001 16:10
nokia 5110 dead alpha Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-28-2001 11:59
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) tcamilo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-19-1999 22:30
Page generated in 0.15601 seconds with 9 queries
