03-05-2008, 14:47 | #1 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Macedonia Age: 43
Member: 10742 Status: Offline Thanks Meter: 13 | dead n95 rm-13 need help pleaseeee THANKS |
03-05-2008, 16:30 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, download files from support area and flash your phone. You need to use files with firmware version similar to original phone version. |
03-06-2008, 11:55 | #3 (permalink) |
Member: 10742 Status: Offline Thanks Meter: 13 | hi dear friend. can you please tell me how to findout what is real firmware version?? support for rm-13 with 2sim has only one flas file..please give mi advise what flash to use thanks |
03-06-2008, 12:02 | #4 (permalink) |
Freak Poster Join Date: Feb 2004 Location: 502-12 Age: 41
Member: 52985 Status: Offline Thanks Meter: 10 | Go to Servise tab for seeing flash file name 1- Click on Read detailed information & Do it process Please see No.2 part in window ver sw1: M678_PCB01_GPRS_MT6226_S01.BC08C-MULTIV01_01B01.BIN This is your flash file name here is the link to know what is ur firmware name ---->http://www./showthread.php?t=499453 |
03-06-2008, 12:28 | #5 (permalink) | |
Infinity-Box makes everything that possible to make any procedure so safe as possible. It's the reason why before any operation Infinity-Box software try to detect existing firmware version and store all operation steps in "operation.log" file, so in case of any problems you always can open this file in any text editor and see original firmare version and many other information. | |
03-06-2008, 13:18 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @cale Infinity-Box is mega-safe. If you make something and don't want to think I have no any words... My advice: remove DELETE button from your keyboard so you will have less chance to delete important files by mistake. |
03-06-2008, 13:33 | #8 (permalink) |
Member: 10742 Status: Offline Thanks Meter: 13 | hi ok ok no problem. I will remove Delete button. now PLEASE help me to rewiev chinase phone... Here is log from phone Initialize... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 damaged, recalculation required identification#1 detection finished device-id: A9FCC396 identification#1 protocol ver: 04 ver. sw1: M8775JLF_PCB01_GPRS_MT6226_S01.M8775TOS_00_11_JL83 47_F.BIN ver. sw2: M8775TOS_00_11_JL8347_F ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98004900000002:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... soo i flash phone with this flash CM_Nokia-N95-RM-13_M8775JLF_PCB01_GPRS_MT6226_S01.M8775TOS_00_11_J L8347_F_16m_En_Ru_Fr_Es_Th_Vn_Ar.B0M CM_Nokia-N95_M8775JLF_PCB01_GPRS_MT6226_S01.M8775TOS_00_11_ JL8347_F_16m_En_Ru_Fr_Es_Th_Vn_Ar.B0M CM_Nokia-N95_M8775JLF_PCB01_GPRS_MT6226_S01.M8775TOS_00_11_ JL8347_F_16m_En_Ru_Fr_Es_Th_Vn_Ar_ver2.B0M CM_Nokia-N95-slider_M8775JLF_PCB01_GPRS_MT6226_S01.M8775TOS_00_ 11_JL8347_F_16m_En_Ru_Fr_Es_Th_Vn_Ar.B0M. and nothing still dead |
03-06-2008, 14:19 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, 1. you must press and HOLD phone "power" button after flashing up to 1 min to make phone powered-on 2. if phone can't power-on you must use another flash file (another firmware version) because exist at least 20 or 30 or 50 different phones with name N95 but with different hardware. |
3120 big problem ... need help pleaseeee!!! | ciprian_stroe | Nokia Hardware & Hardware Repair | 10 | 07-11-2009 19:49 |
N95 rm-159 need pin out help!!!! | arblitz86 | Chinese Models & Cloned Phones | 1 | 01-10-2009 05:51 |
n95 rm-13 | adelgsm | Infinity-Box | 1 | 12-12-2008 20:41 |
n95 rm 13 rx tx gnd help | ceptel | Chinese Models & Cloned Phones | 1 | 06-06-2008 21:18 |
